AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 18-10-2006, 3:47 PM   #1 (permalink)
pure_geordie's Avatar
Thanks: Gave 5, Got 14
Breaking Glass
A bit of a science Q here, my glass broke in my cinema room just on the inside of the duoble glazed 4mm thick window around the top towards the centre of the window. It seems to happen when I have my cinema room cranked up. I use these http://www.tannoy.com/Default.asp?Id=7946
It is unexplained and weird or could it be something else. Outside of the glass is fine and there is no movement on the top.
Is this possible or a stupid theory because I cannot think of anything else
Pioneer DV696, Pioneer VSX916, Tannoy HTS200, Hitachi PJTX200 Projector, Philips Matchline III 100hz 32"TV, Satallite, Sony VCR, Panasonic SCHT900, Media Centre PC, Sapphire 89" Electric Screen, Running 10 Metre Comp/VGA, PS3/PSP
pure_geordie is offline
Old 18-10-2006, 11:06 PM   #2 (permalink)
Gary Lightfoot's Avatar
Thanks: Gave 5, Got 305
Re: Breaking Glass
Has it happenned more than once? Is the room small and you're over pressurising it with the sub maybe?
Gary
My Old Home Theater
Basic Projector Calibration
Gary Lightfoot is offline
Old 22-10-2006, 7:10 PM   #3 (permalink)
Thanks: Gave 31, Got 206
Re: Breaking Glass
Seriously doubt its anything to do with your sound levels.
Mr.D is offline
Old 22-10-2006, 10:06 PM   #4 (permalink)
Re: Breaking Glass
Any unserious doubts Keith?
Gary
My Old Home Theater
Old 23-10-2006, 1:29 PM   #5 (permalink)
Re: Breaking Glass
I think it must of been a one off, the chap who replaced my windows said it just popped!!
Sometimes this just happens. Only just happened the once.
Thanks for input
Old 23-10-2006, 7:29 PM   #6 (permalink)
Pecker's Avatar
Thanks: Gave 865, Got 754
Re: Breaking Glass
I know the old 'glass shatters when opera singer sings' phenomena is not totally to do with volume, but also with the frequency being output (in this case by your A/V set up). If the frequency is the same as the one at which your glass resonates, that might have broken it.
What were you playing?
Steve W
My Third Home Cinema
Read My Blog
List your DESERT ISLAND FILMS here
Pecker is offline
Old 26-03-2007, 6:54 PM   #7 (permalink)
Question Re: Breaking Glass
Hello again. This has happened again
my glass got replaced 5 months ago and the glass has broke on the inside of my window again.
This is so weird, noticed it the day after the night before I was watching Star Wars III so I must be my Sub or something. Is this possible.
Any thoughts on this anyone Can't believe it my crack is about 1 metre wide
Old 26-03-2007, 7:22 PM   #8 (permalink)
Re: Breaking Glass
Bragging rights won't get you anywhere on this forum meladdo.
Only what has been said previously, or has some one been playing ball in the room? Perhaps the vibration is causing the entire door to vibrate and that's the result.
Gary
My Old Home Theater
Old 26-03-2007, 7:37 PM   #9 (permalink)
Re: Breaking Glass
No-one has been playing with my balls.
It must be down to sound vibration It can be anything else. I must have a very powerfull sub Its not the most expensive and powerful one by far you can buy but?
I will now get my 4mm glass replaced again with 6mm Toughened glass which will also help with sound proofing. All for £97.00.
Good job my brother in-law fits windows and doors.
Cheers gazza!
Old 30-03-2007, 3:40 PM   #10 (permalink)
nal
Re: Breaking Glass
The glass could have been stressed with expansion/contraction. Had a double glazed bedroom window replaced 5 times after a crack appeared in it only days after each fitting and then last week a patio door panel went bang. Don't know why as it's been in 12 years and gets the sun most of the afternoon, it sounded like a football hitting the pane but it was the inside that blew.
nal.
nal is offline
breaking, glass
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sky+ Breaking up Marvin02 Sky and Sky+ 10 24-05-2006 9:47 AM
Need help breaking my plasma!!!! Yankee Ruin X Plasma Televisions 24 13-04-2006 2:32 PM
Breaking up neilo General Chat 130 10-03-2006 9:56 AM
More4 breaking up Peter Baker Satellite TV 0 28-12-2005 10:59 PM
TM13U keeps breaking tigermad Remote Controls 0 08-02-2004 5:37 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
