AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 26-09-2006, 2:06 AM   #1 (permalink)
Jazz Monkey Jr's Avatar
Thanks: Gave 197, Got 178
Garage soundproofing - planning
I am planning to turn my garage in to a cinema room, I am starting from scratch although the ceiling is already plasterboarded/plastered due to the extension above it.
I want it well soundproofed, I am going to go for the stud/rockwool, soundbloc/green glue/soundbloc way nn the walls/ceiling. I will probably rip the old ceiling down to get cables in.
I have a small window at one side (the outside wall), I am going to brick up the front and put a window in, see pic. The other side wall is joined to the house therefore is a cavity.
My question is: How much sound will I loose out of the windows? I was thinking about putting an extra layer of greenglue/soundbloc but there isn't much point if loads of sound is going to go out of the windows.
Also is it worth doing the floor, I am going to put a floating floor it, is it worth green glue in between the styrofoam/chipboard?
Any advice, please.
AV: Panasonic TH-42PV500
Digital SLR: Canon 350D with Sigma 10-20mm, Canon 24-105 f4 L IS, Canon 50mm f1.8, Speedlite 430EX and handgrip, Crumpler Geekstar MY PICS---FLICKR
Consoles: XBox 360, Wii, PS3, Gamecube, N64, Black NDS lite, R4DS
Jazz Monkey Jr is offline
Old 27-09-2006, 9:26 AM   #2 (permalink)
Re: Garage soundproofing - planning
Would is be a good idea to put 2 double gazed units to keep the sound in? Would they need to be toughened?
Old 27-09-2006, 9:31 AM   #3 (permalink)
Thanks: Gave 110, Got 108
the window i dont know about, but the floor, if you put green glue down in the same way as your wall, sandwiched between layers, it will work best that way
mattym is offline
Old 27-09-2006, 10:15 AM   #4 (permalink)
It is going to be a floating floor, so I would put it between the floor insulation (syrofoam) and the chipboard?
Also how much is the green glue, I reckon I will need 40 sheets of soundblock (doubled up) so that will be 40 tubes of green glue (2 tubes per sheet) which is 4 cases.
garage, planning, soundproofing
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Planning ahead for Garage conversion Jazz Monkey Jr Audio Processors and Power Amps 15 25-09-2006 2:12 PM
Planning stages - Garage conversion Jazz Monkey Jr Home Cinema DIY 4 22-09-2006 8:02 PM
SoundProofing Garage lutonian Home Cinema DIY 2 08-09-2006 6:59 PM
Garage Soundproofing baggies1 Room Acoustics, Audio and Video Calibration 3 13-04-2006 10:30 PM
Planning permission for a garage conversion? Ste7en Home Cinema DIY 15 27-02-2006 10:03 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
