19-09-2006, 9:00 PM
#1 (permalink)
Thanks: Gave 5, Got 1
Roll down soundproofing?
My theater room is very irregularly shaped. The walls are gypsum/plaster. I need to make soundproofing roll down from the ceiling on 3 sides of the room to make a rectangle. Im going to make DIY electric rolls but i just dont know what material to use as soundproofing that can be spooled (rolled) up.
19-09-2006, 9:12 PM
#2 (permalink)
Super Moderator
Thanks: Gave 147, Got 506
Re: Roll down soundproofing?
Moving this to a forum area where you may get more help!
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
19-09-2006, 11:36 PM
#3 (permalink)
Thanks: Gave 5, Got 305
I don't think you'll be able to soundproof the room as you really have to seal all routes that the sound can travel through. You may be able to mute it a little, but not enough to make a real difference unfortunately. It will make accoustic differences though, depending on what materials you'll use.
Gary
My Old Home Theater
Basic Projector Calibration
20-09-2006, 3:28 AM
#4 (permalink)
I have a good start anyway, walls are realy thick plaster so i definaly wont have any "hollow" effect. Two walls go to the outside where there is brick.
Maby my term soundproofing was a bad thing to say, im not worried about sound coming in, a little worried about sound going out but the main thing i want to do is to stop reverberations and make the room a rectangle. I think sound deadening is a better term, i just want to stop the sound from reflecting.
I guess my question now is, is it worth it? Im building a quite high end system, electrostats, tube amps ect. If i can get some good material i cant probably make the room for the most part sealed off, not air tight but close. I plan to put it on the ceiling to, just for looks mostly but it might help the audio side a bit. I already put audio insulation in the attic a long time ago, and then more regular insulation was blown in.
I need carpet underlay too.
I think i need something like this exept with good user rateings: http://cgi.ebay.com/SOUNDPROOFING-NO...QQcmdZViewItem
Any suggestions will be appreciated
thanks
20-09-2006, 7:04 AM
#5 (permalink)
Thanks: Gave 110, Got 108
what shape is the room now? You can buy acoustic treatments that you can stand and move around etc, the idea is to balance the room as best as possible.
Can you email me or post a plan of the room?
20-09-2006, 9:37 PM
#6 (permalink)
21-09-2006, 7:29 AM
#7 (permalink)
you dont have to cover that whole area, you can just use screens over the opening, then get the rest of the room treated accordingly, rather than killing the whole room off
22-09-2006, 8:38 PM
#8 (permalink)
what? screen what off? so i should have roll down screen? im confused
22-09-2006, 8:57 PM
#9 (permalink)
lol sorry, i was at work so didnt have much time to expand
the opening on the top right, use moveable screens(acoustic ones)to place over that opening, you can then look at treating the room in a more standard fashion, like standard panels or more moveable ones
are you looking to completely deaden the room, or leave some life in it?
22-09-2006, 11:58 PM
#10 (permalink)
I want it as dead as possible  . Im not too worried about the sound getting out or sound coming in alot. I just dont want the sound bounceing. Im lazy and i dont want to have to move panels back and forth. I just wanted somthing that could be rolled down easy or hung easy. I already have basicly everything needed to make a few electric rollars so i figured this would be a cool thing to do since i want to keep this room functional for guests ect.
23-09-2006, 12:49 PM
#11 (permalink)
well you can buy curtains that would do the job, but you risk having a poor sounding HT setup if you over-damp it in the high end and take no notice of the mids and lows
24-09-2006, 4:05 AM
#12 (permalink)
Ok curtains sound good. What sould i get? Is it going to be quilted curtains like the stuff on ebay or curtains on a rail like a window? Will i still need a roller or just a rail?
24-09-2006, 10:06 PM
#13 (permalink)
rails would be better, but thats down to your own personal taste i think
02-10-2006, 8:31 PM
#14 (permalink)
Ok so is the stuff on ebay alright or should i get somthing different?
