AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 09-09-2006, 3:51 PM   #1 (permalink)
Speaker placement/room acoustics
Will either of these placements yield better audio response?
The main use for this will be movies, however there will also be some music listening.
Dimensions are L-4.5m, W-3m, H-2.8m
If anyone has any informative links on room acoustics/speaker placement that would be appreciated.
Thanks,
Nemz.
Nemeliza is offline
Old 09-09-2006, 7:48 PM   #2 (permalink)
Thanks: Gave 15, Got 6
Re: Speaker placement/room acoustics
Personally I favor "A".
I think it will give you a sence of depth. I have a simular set up and am very pleased with the results.
"B" will muddle the sounds as the speakers are too close.
IMHO
jmsjabb is offline
Old 10-09-2006, 2:20 PM   #3 (permalink)
Ethan Winer's Avatar
Lightbulb Re: Speaker placement/room acoustics
Nemz,
> Will either of these placements yield better audio response? <
Yes, A will be much better because it has the potetantial to put the wall much farther behind you. As you show A, you'll be sitting too close to the wall on the right side of the drawing. The ideal place is 38 percent of the way into the room from either the front or rear walls. Ideally you'd be up close to the speakers, which minimizes the contribution from the room. But second best is 38 percent of the way in measured from the rear wall behind you.
The first drawing below shows this in context, along with first reflection treatment locations. The second image is the response measured in a room using your A and B orientations. It's clear that the bass response is much better with the speakers firing the longer way down the room.
> If anyone has any informative links on room acoustics/speaker placement that would be appreciated. <
There's a ton more advice like this on my company's web site realtraps.com.
--Ethan
Ethan Winer is offline
acoustics, placement or room, speaker
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Room Layout & Speaker Placement - Help needed ukguy4672 Speakers 15 07-08-2006 1:52 PM
room layouts & surround sound speaker placement? Stuart P Speakers 2 23-06-2006 8:10 AM
room layouts & surround sound speaker placement? Stuart P All-in-one Systems 2 22-06-2006 8:28 AM
Corner Room Speaker Placement paulhulatt Room Acoustics, Audio and Video Calibration 1 19-07-2005 3:42 PM
Speaker Placement in a square room. karkus30 Hi Fi Systems and Separates 4 29-02-2004 9:11 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
