07-09-2006, 2:15 PM
#1 (permalink)
Thanks: Gave 7, Got 5
speaker delay set up
Just reading in What HiFi about setting up the delay for the speakers. They say measure from the seating position to the front left speaker, and then to the rear left speaker. For every 150cm difference add 5ms delay....
does the delay go on the front or rear speaker though? - sorry for being a dumb ass!
07-09-2006, 3:14 PM
#2 (permalink)
Thanks: Gave 69, Got 793
Re: speaker delay set up
It normally does all of them, individually settable mate
ASTON VILLA
I don't know what I'm supposed to think, so I guess I'll have to make my own mind up.
07-09-2006, 3:54 PM
#3 (permalink)
Thanks: Gave 4, Got 43
Hi there,
Speaker delays are usualy for all but the Front Main pair of speaker (or Normal Stereo pair) as these are considered the reference from which the delay is taken. Having delay on these would be nonsensical, save in lipsych errors. though that is typicaly a different setting.
IIRC at the speed of sound 1ms of delay equals 30cm/12" which would be the same as 150cm = 5ms so its 'sounds' about right.
cya,
Lee
My Way Over the top LOTR based Home Cinema
Curently For Sale: Nothing
07-09-2006, 4:06 PM
#4 (permalink)
That's plain wrong.
On both my Yam 557 and Denon 3803, you can set the delay on all speakers.
It even asks the distance for all speakers in the basic setup.
ASTON VILLA
07-09-2006, 6:11 PM
#5 (permalink)
Thanks: Gave 83, Got 490
amps from the last few years usually prefer you to set a delay for each speaker going on distance from seating position.....
however some older amps had it as a setting for the rear speakers jointly from the front speakers......my old Sherwood does it like that....
so i guess it depends on the amp...
badger mate, tomorrow the rather large rosewood finished eagle lands
HC: Infocus 7205, Denon 3803/3910. MA Silver S6, SFX, S2, SLCR. SVS PB12/Plus. Sky+.
Hifi: Musical Fidelity A5, Denon 3910 CD/SACD/DVD-A. Monitor Audio GR10's.
PC: E6700, Gigabyte DS3 965P, 2Gb Corsair, Gainward 8800GTS 640Mb, CL X-Fi Fatal1ty, Jeantech 600w, Antec Sonata II.
07-09-2006, 7:20 PM
#6 (permalink)
Alaric,
My apologies.
I've made you look a bit of a mug, when you are slightly correct.
You probably know this already, but for anyone else, I'll explain.
The picture travels from the telly at the speed of light, so we can generally take it that the pic hits you instantaneously.
The sound will take longer, hence the reason for having a delay setting for each speaker.
Also remember, not all front speakers are the same distance from the listener, hence another good reason for individual delay.
Of course, If you're only listening to music, it doesn't matter (assuming the fronts are at equal distance) as you correctly said
In this case it can be considered as zero, if you're using stereo only.
But if listening to surround music and the rears are closer, you would need delay, as the rear sound will hit you quicker. That begs the question, if your fronts are say, 5m away and your rears are 2m away, what do you set the rear delay at?
I know the answer, but I'm sure it's easier to use the actual measurements
KB,
I've been watching mate, no worries.
I await your opinions
ASTON VILLA
07-09-2006, 7:21 PM
#7 (permalink)
thanks for the replies. My rerar speakers are a lot closer to my seated position than the fronts, so am I right in thinking I need to set some delay on the rears then? (ive not actually measured anything yet!)
07-09-2006, 7:34 PM
#8 (permalink)
Definitely.
Although you may not even notice the difference, it may help with back to front panning.
ASTON VILLA
07-09-2006, 7:38 PM
#9 (permalink)
Hi There,
Curious...And i can see the thinking.
Admitedly my Yamaha AX1 is an older amp and my prior amps have never had a feature to delay the fronts. Looking on the Nvidia decoder, there are just rears and centre.
It also depends if its for movie or music use as SACD/DVD-A have a circular set-up where any speaker can be the master.
I guess the correct answer is the usual one of read the manual and adjust per the manufactures instructions
cya,
Lee
07-09-2006, 7:40 PM
#10 (permalink)
Nice one
Later
ASTON VILLA
