AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 03-09-2006, 12:04 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Calibration help
I have just bought a HD DVD and wish to get the best pic and come across threads about calibration (taken me all that time to find out about calibration )
I have read thought the threads on calibration
I have a Plasma 43"
I came across products like sypderTV anygood? Also the Calman software
Would be greatfull of help on what would be best software and hardware with out breaking the bank..
Many thanks
raw27 is offline
Old 03-09-2006, 12:19 PM   #2 (permalink)
Thanks: Gave 31, Got 206
Re: Calibration help
Calman with a spyder2 sensor and a suitable test disc would be the one to go for.
Mr.D is offline
Old 03-09-2006, 12:22 PM   #3 (permalink)
Hi Does the above items not come with a test disc then
Many thanks
raw27 is offline
Old 03-09-2006, 1:00 PM   #4 (permalink)
Depending on which spyder package you buy it will have test discs of some description but calman assumes you have either Avia , DVE pro or Getgray.
there is a pattern generator stage built into calman but its still beta I belive and probably only useful if you are calibrating an HTPC. The getgray discs are probably the best option for you if you don't have any of the others.
If this is your first bash at calibration I'd recommend you grab a copy of the domestic version of DVE and use that for the time being before you move into calibrating grayscale with a spyder. Its not rocket science but you'll find it necessary to be familiar with certain concepts and terminology.
Mr.D is offline
calibration
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Calibration? RICARDDO Plasma Televisions 10 24-05-2006 7:08 PM
Z4 calibration paul1967 DLP, LCD and D-ILA Projectors 0 27-01-2006 10:47 AM
Tv Calibration by my own booker CRT Televisions 3 29-03-2005 12:07 AM
Calibration...is this OK? VFRMan CRT Projectors 4 05-03-2005 8:55 PM
Calibration phfjones Room Acoustics, Audio and Video Calibration 0 18-11-2004 5:46 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
