AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 31-08-2006, 9:45 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Wall soundproofing - space at a premium
I want to improve the sound proofing of the wall joining my house to my neighbour.
I've read up a lot and appreciate a detached false wall is the optimum. Issue I have is that the stairs run up the wall to be improved - hence I can't lose 2-3", and instead only have an inch or so to work with - a little more than the width of the skirting.
With this is mind - has anyone got any recommendations? The sound coming through the wall is Low, but I really want to reduce it further. Secondly, I'd like to run my kit a little louder without concern for the neighbours who thus far (fingers crossed) haven't said a word.....
Lounge | Pioneer 436XDE | Denon 3910 (Denonlink 3) | Denon AVR-4306 | Arcam P90 Bi-amp | B&W 704 6.1 | SkyHD |
Gaming Room | Toshiba 32WLT68 | XBox 360 Premium | Yamaha YSP-800 |
Bedroom | Samsung LE23R41B | Sky+ | Recently Added | Sony Vaio XL100 Media Centre |
NS-UK is offline
Old 01-09-2006, 7:40 AM   #2 (permalink)
AVF Technical Consultant
Neil Davidson's Avatar
Thanks: Gave 37, Got 175
Re: Wall soundproofing - space at a premium
In this situation it would seem that Green Glue is the best option. You would get best results from removing all current plasterboard (assuming not plaster walls) then applying a double layer of new boards as per the Green Glue instructions.
Wouldn't loose much space,1/2" or so, but would have significant reduction in noise levels both ways.
Neil
Neil Davidson
Genesis Technologies
My opinions are my own and not those of AV Forums or its related websites
Neil Davidson is offline
Old 01-09-2006, 4:50 PM   #3 (permalink)
Thanks!
Would you also recommend a particular plasterboard / thickness plasterboard?
NS-UK is offline
Old 01-09-2006, 6:08 PM   #4 (permalink)
anfieldfc
Posts: n/a
if your using green glue just use 12.5mm plasterboard
Old 01-09-2006, 7:55 PM   #5 (permalink)
Thanks: Gave 16, Got 71
I asked about adding plasterboard and Green Glue to an existing wall without the traditional air gap, the response was that they thought it would work but had no tests to prove it
Londondecca is offline
Old 01-09-2006, 8:00 PM   #6 (permalink)
Thanks: Gave 110, Got 108
Block wall is currently untested(afaik), but a plasterboard wall or stud is well documented and tested..
mattym is offline
Old 01-09-2006, 11:04 PM   #7 (permalink)
My apologies, I was referring only to brick walls, there is huge amounts of information on stud walls and plasterboards. Sorry for any confusion.
I still have some plasterboard to be fixed to a brick wall and I am tempted to use some Green Glue between the plasterboard and plaster/bricks. I still have two tubes of GG, so I have nothing to lose by trying.
This is a quote from Brain R from AVSforum in response to my question
"we don't possess brick-wall test data to answer that question at this time. the damping effect of green glue would be very valuable on a masonary construction, the question is "would green glue be effective in that situation?"
And i do regret that i cannot really answer what the results would be. Its a priority of ours to run a series of tests with masonary to support European customers (as this wall, while rare here, is very common in the UK and Europe), but this data won't be available for a month or 3.
The best support for your question that we can offer on a reasonably short-term basis would be a lab damping-only test (but this couldn't readily be converted into actual sound transmission data, only into estimates)
In some situations, adding drywall to masonary is a good idea as it allows the chance to caulk/seal the wall - seal failure via cracks and things seem to be common in masonary constructions"
http://www.avsforum.com/avs-vb/showthread.php?t=693134
premium, soundproofing, space, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Metal vs Wood for framing a soundproofing wall eezjib Home Cinema DIY 6 19-08-2006 1:06 PM
Soundproofing with space at a premium p203557 Room Acoustics, Audio and Video Calibration 6 05-08-2006 6:12 PM
Solution for small space and no wall hanging? Worf55 AV Stands, Cabinets, Seating and Furniture 3 25-04-2006 6:45 AM
Wall inset for 435XDE. How much breathing space? yellowpostit Plasma Televisions 5 17-08-2005 10:27 AM
Soundproofing a party wall finbo Home Cinema DIY 7 16-04-2002 5:57 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
