AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 30-08-2006, 10:30 AM   #1 (permalink)
Thanks: Gave 31, Got 206
DIY video test patterns
After a bit of fiddling about I'm confident I can create and encode mpeg2 test patterns with accurate levels. I can probably also generate 1080i/1080p ones ( or any other res for that matter).
I often find the test patterns on DVE and others a little coarse with regards to the levels they represent. I've made my own pluge that delineates 0 , 16 , 18 for setting black point correctly (clips on 16 but 18 still visible).
I'll probably bang one out that delineates 235 to 255 for white point ( although I set for visibility right up to 254 for white ref anyway but a pattern with clearly marked levels close to 254 could be useful , : the belle-nuit one pretty much does this anyway).
So does anyone think this will be useful or do you have everything you need on DVE and the others?
I'm looking into interlacing so should be able to create some common cadence situations : 2:2 pulldown , 3:2 pulldown , 50i , 60i . Mixed cadence on same image etc.
Strangely enough the trickiest part of all this is making sure the encoding behaves itself but tmpgenc seems to be persuadable.
HD-DVD type test patterns may also be a possibility if I can get the time to investigate the issues involved.
I was also thinking it would be nice to host these on the forum if possible ?? Figure the AV forums might as well have its own test patterns. I could also post only the single image file as a tiff and leave the encoding up to you lot individually if that's easier. Obviously won't work for the animated ones though.
Any thoughts?
Mr.D is offline
Old 30-08-2006, 4:40 PM   #2 (permalink)
AVF Technical Consultant
Neil Davidson's Avatar
Thanks: Gave 37, Got 175
Re: DIY video test patterns
Get Grey does what I need for test patterns (but often you never know you need something until you try it) but a 50Hz DVD for evaluation of the displays processing is very much something I would be interested in seeing.
Luciano Mehringhi (sp?) posted an interesting DVD working towards this a while ago. Might be worth looking at that for an idea on what he had acheived. Plus a look at some of the items in the Peter Finkel DVD.
Looking forward to seeing what you can come up with.
Neil
Neil Davidson
Genesis Technologies
My opinions are my own and not those of AV Forums or its related websites
Neil Davidson is online now
Old 31-08-2006, 7:35 PM   #3 (permalink)
Just done some tests and yes I can render out examples of 2:2 , 3:2 pulldown , 50i and 60i.
Mr.D is offline
Old 31-08-2006, 9:29 PM   #4 (permalink)
eviljohn2's Avatar
Thanks: Gave 66, Got 187
I'm very interested in whatever you can come up with Keith.
See no AV, Hear no AV, Speak no AV.
Congratulations! You found the hidden text.
Mario Kart Wii Name: Gibbo
eviljohn2 is offline
Old 06-09-2006, 2:04 PM   #5 (permalink)
merifon's Avatar
Thanks: Gave 0, Got 17
Neil
The correct spelling is: Luciano Merighi. Don't worry, even italian people sometimes make a mistake...
Anyway, if anyone wants to take a look to home brew TestDVD, I repost the link:
http://digilander.libero.it/merifon
saluti M
merifon is offline
Old 06-09-2006, 2:43 PM   #6 (permalink)
Thanks for that
Having had a look at the available options. I'm wondering if there is any real necessity for anything other than some different cadence examples. However if anyone wants something not covered in any of the other options then I'm happy to knock up a test mpeg for you.
Mr.D is offline
Old 06-09-2006, 3:20 PM   #7 (permalink)
Alaric's Avatar
Thanks: Gave 4, Got 43
Hi There,
On a slightly different side, i've been looking for a decent focus patern for my CRT. The best i've found so far is the double box with 9 tripple rings on the Philips test patern generator (v3). However this only has a 5 boxes, one in the centre and one in each corner, which is fine for optical focus (centre & Edges) however the electromagnetic focus is Centre, Top, Bottom, Left & Right....which only the centre one is useful for !!!
I guess i'm going to have to mimic the Nokia one in Photoshop or something....However then its resolution dependant and is not actualy part of the DVD chain (not that the nokia one is either) !
A set of DVD based looped focus patern may be useful.
Oh and maybe the + style intermitant green & magenta crosses for convergance
I wouldn't mind looking at those brightness/contrast paterns as to be honest DVE/Avia are great but the navigation is always a pain.
cya,
Lee
My Way Over the top LOTR based Home Cinema
Curently For Sale: Nothing
Alaric is offline
Old 06-09-2006, 3:36 PM   #8 (permalink)
All seems easy enough. The convergence pattern : when you say alternating how fast would you want? Every couple of frames so its strobing or just alternating every 5 secs or so?
The focus one seems easy enough .Its reminded me of one final test I need to make on my image pipeline to see if the encoder is handling non square pixel 720x576 and 720x480 correctly.
Mr.D is offline
Old 06-09-2006, 4:38 PM   #9 (permalink)
Alaric's Avatar
Hi There,
*Laugh*
I meant alternating in colour. Convergance is used to match (normaly) red and blue (hence magenta) to green. The typical patern is a set of horizontal and vertical lines that create a grid of boxes. This is a good patern for initial convergance, but should the red or blue be a different width (sharper focus) to the green then as soon as they aline you loose any sense of acuracy.
By having a patern of +++ that alternate in colour between green and magenta, aligning them edge to edge you never actualy overlap and hence can effectivly see how the colours actualy relate to each other without one effectivly canceling the other out.
Thanks,
Lee
Alaric is offline
Old 06-09-2006, 5:00 PM   #10 (permalink)
Just a heads up that there is similar discussion going on in the VP forum - perhaps a joint project brewing?
Neil
Neil Davidson
Old 06-09-2006, 6:25 PM   #11 (permalink)
clarky78's Avatar
Thanks: Gave 17, Got 27
I dont even understand what you said, but it sounds interesting!
clarky78 is offline
Old 06-09-2006, 9:50 PM   #12 (permalink)
Thanks,
Lee
Yes I know the pattern you mean how quickley would you want it to alternate is what I'm asking.
Mr.D is offline
Old 06-09-2006, 9:55 PM   #13 (permalink)
Neil
Can't see it neil what one is it?
Mr.D is offline
Old 06-09-2006, 10:00 PM   #14 (permalink)
Miniholic's Avatar
Thanks: Gave 488, Got 363
Keith, IIRC the colour of the individual crosses remains static, something like this.
Then, when perfectly converged the crosses will line up horizontally, and vertically.
Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, AE500 & NS830 VCR.
Carada Criterion 92" fixed screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is offline
Old 06-09-2006, 10:31 PM   #15 (permalink)
Ah gotcha , even easier .
Mr.D is offline
diy, patterns, test, video
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Test Patterns garyc Computer Systems 3 29-10-2005 6:20 PM
iscan HD test Patterns vancouver Video Scalers, Video Processing and Progressive Scan 3 20-02-2005 9:39 PM
The DV32R/FLR video test patterns lenny TAG McLaren Audio Owners' Forum 3 16-02-2005 8:29 PM
some test patterns jmack Plasma Televisions 0 28-12-2002 7:58 PM
Faroudja test patterns/clips Oblivion Movies and The Cinema 0 25-09-2002 11:04 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
