AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 27-08-2006, 2:48 AM   #1 (permalink)
Thanks: Gave 45, Got 13
Question How to calibrate Sky
Ok my setup can be seen below, with the ES10 feeding the iscan HD+ through component and the SkyHD box feeding the iscan HD+ through HDMI. The iscan HD+ then feeds the Sharp through HDMI @ 720P/50Hz.
I can Calibrate my es10 using a DVD based system (DVE,THX or even SpyderTV) and have done so only adjusting the setting in the iscan controls, but how do I calibrate the SkyHD input into the TV?
All I can think off is to use a HDMI equiped DVD player and calibrate the TV HDMI input using that. Is there another way?
And why don't sky have a calibration channel?
I know the Sky feed looks wrong/different to the DVD feed so it needs doing and I am not experienced enough to do this by eye at the moment.
CrispyToast In The Living Room: Panasonic TH42PHD8, SkyHD, HK 8500, Kef iQ5,iQ6c & iQ1, Panasonic "DMR-EH50", HDQ Video Processor, Denon DVD-2900 SDI.
CrispyToast is offline
Old 27-08-2006, 8:58 AM   #2 (permalink)
Thanks: Gave 31, Got 206
Re: How to calibrate Sky
The only way to do properly would be for Sky to broadcast a test pattern.
All you can really do is assume a dvd player is somewhat accurate on the output stage and calibrate to that as a starting point, if you notice any massive deviations relative to the sky box then tweak by eye.
You might find with hdmi that the deviation between sources is fairly minimal , I've found the component output on lots of players to be very close to each other.
Mr.D is offline
Old 27-08-2006, 2:50 PM   #3 (permalink)
AVF Technical Consultant
Neil Davidson's Avatar
Thanks: Gave 37, Got 175
As Keith says, in the absence of Sky broadcasting some test patterns (and lord knows they've been asked often enough to consider it) you have to try and use another method.
I have a calibrated signal generator which I use to ensure that the input has been greyscaled as close as possible to industry standards. Then switch over to the sky box and set brightness, contrast and colour by eye. There are a few tricks that you can use to do this properly.
Whilst not the "perfect" results you can get from DVD the improvements are still usually dramatic.
Neil
Neil Davidson
Genesis Technologies
My opinions are my own and not those of AV Forums or its related websites
Neil Davidson is offline
Old 27-08-2006, 3:38 PM   #4 (permalink)
Ok thanks, I am on the right track then.
I also should calibrate my Sky+ box so if I remember right the sky box can pass through a picture on it's scart connectors would that be a better way to calibrate my other Sky+ box than running a dvd player on the same TV scart.
Old 28-08-2006, 9:47 AM   #5 (permalink)
Ok did this today using a DVD player on both the SkyHD and Sky+ and I am happy with the results. The scart connected Sky+ box needed a bit a fine adjustment, but the HDMI SkyHD setup seems spot on.
calibrate, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
How Do I calibrate Sky TV on my DLP? Paulherb Rear Projection Televisions 2 18-02-2008 5:25 PM
Need 5.1 Testfiles to calibrate sub. Please :) damenace Subwoofers 29 08-08-2006 2:50 PM
calibrate - what is it JTR Plasma Televisions 4 25-04-2005 6:42 PM
calibrate THE BOARS Plasma Televisions 2 26-11-2004 9:02 AM
Anyone near us calibrate tvs?? steviebee CRT Televisions 6 02-11-2004 12:43 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
