Originally Posted by binbag I've been mulling the idea over of getting a sheet of MDF and sticking different offcuts of wood on it, different woods, different heights in a blockboard sort of arrangement - kinda like a city viewed from above. Varished up it should look OK and from what I've read of acoustics should work as a diffuser. |
As Matty says, it will. It doesn't need to follow a particular pattern either, wholly random is effective (within the bound of diffusor design). The only difference is that you can not predict the scatter pattern. Two points to bear in mind though: first that it takes far more wood than you would imagine. Your offcuts pile would need to be substantial even for a 2' x 2' panel. Second, weight soon becomes an issue. Again, even a 2' x 2' panel will have considerable weight. And weight has all sorts of sub-points to bear in mind, but not least the target wall/ceiling construction (plasterboard is a common wall/ceiling material, and woeful for heavy duty fixing).
How do I know this?. Because I have a DIY 4' x 2' (approx) panel at my primary ceiling reflection point. OK, so I have a plaster/lath ceiling suspended from 12" depth joists, so fixings are rock solid, but the effort getting it there (myself!), well that's another story
