Onkyo 906 & mordaunt short mezzo 2, 5, 8, 9
Old 16-11-2009, 10:19 PM   #1
1,347, Level: 8
Points: 1,347, Level: 8 Points: 1,347, Level: 8 Points: 1,347, Level: 8
Thanks: Gave 1, Got 0
Hi there i have the Onkyo 906 Amplifyer, and the mordaunt short mezzo Range
im useing Mezzo 2 as Back surround Speakers
and the 5 as Center Speaker
the 8's as Front floor standers
and the Mezzo 9 is my sub,
I have had them all for about 6 months now, and getting used to it All, But one of the things i have noticed but never really known what to pop there, is under Speaker Config under my Onkyo 906's setup it lets me set up the "hz" of my speakers now i know what it means, but im not sure what it wants me to pop there as this is my first Proper system, it lets me choose for Each speaker ( or set at least like front back sub Center ect ect.)
it lets me choose from between 40 Hz - 200Hz for each one and under 80 is States (THX) <---- Just like that and then under my frount speakers it also lets me choose FULL RANGE,
Anyone got any idears? i was thinking about digging my Manual out again but not much luck as its in the loft in one of many Boxs D:
any help will be helpfull!
Thanks a lot, and sorry about the Bad Spelling.
Puregreen.
Old 17-11-2009, 10:28 AM   #2
1,347, Level: 8
Re: Onkyo 906 & mordaunt short mezzo 2, 5, 8, 9
bump! D: any info is better than none, looking at my Speaker Specs it Says they can go at 35Hz - 22kHz So im going to take a guess and Say that i should pick the Lowist number nearist the "35Hz"?
Old 17-11-2009, 1:15 PM   #3
4,031, Level: 14
Points: 4,031, Level: 14 Points: 4,031, Level: 14 Points: 4,031, Level: 14
Thanks: Gave 58, Got 40
I am using an Onkyo 875 with Kef IQ9s front, IQ1's rear, IQ6 centre and an SVS sub. I set my left and right to 80hz THX, and my centre and rears to 120hz. This way the fronts don't deal with any sub frequencies - nothing below 80hz. I have set the rears and centre to higher so that they only deal with higher frequencies as I didn't want the centre or rears being too bassy. Remember to make sure that the Sub is selected (can't recall if it does it automatically).
Works well for me.
Per
puregreen59 (17-11-2009)
Old 17-11-2009, 5:14 PM   #4
1,347, Level: 8
ah, okay Thanks, just a quick one what are the Advantages of setting speakers lower or higher?.. still very new at all this
I am Loving the sound tho, but i want to make it Better!
