Centre Speaker angle
Old 01-11-2009, 10:44 PM   #1
3,796, Level: 14
Points: 3,796, Level: 14 Points: 3,796, Level: 14 Points: 3,796, Level: 14
Thanks: Gave 48, Got 27
I've seen on the forum that the centre speaker should be placed as centrally and underneath the tv. With some TV stands this is not possible.
For alternative positions in a TV stand or even on the floor, should the centre speaker be angled towards ear height?
Also does it matter if it's not exactly in the centre underneath the tv?
Thanks.
Old 05-11-2009, 9:45 AM   #2
3,796, Level: 14
Re: Centre Speaker angle
Anyone?
Old 17-11-2009, 5:29 PM   #3
leon's Avatar
8,658, Level: 22
Points: 8,658, Level: 22 Points: 8,658, Level: 22 Points: 8,658, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 16, Got 56
should be ok just of centre if u calibrate you amp after .if u angle it u will get better results
bloodynora (22-11-2009)
Old 20-11-2009, 3:11 PM   #4
Assured Advertiser
Liam @ Prog AV's Avatar
27,694, Level: 40
Points: 27,694, Level: 40 Points: 27,694, Level: 40 Points: 27,694, Level: 40
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 6, Got 803
Ideally you don't want the centre speaker to be more than 10deg out of line in height from the side speakers. But we don't live in an ideal world so yeah just tilt your speaker to aim at your ears
How much does a cockney pay for shampoo? Pantene
call me: 01892 860801 / e-mail me: liam@progressive-av.com / twitter me: @ProgressiveAV
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
