Using a Spyder 2 Express to calibrate projector
Old 29-10-2009, 4:17 PM   #1
1,000, Level: 7
Points: 1,000, Level: 7 Points: 1,000, Level: 7 Points: 1,000, Level: 7
Thanks: Gave 4, Got 4
Hi, is it possible to use a Spyder 2 to calibrate my projector? The blurb refers to calibration of monitors only, so i'm a bit unsure whether it would be suitable for calibration of the projected image on my screen.
There are some references on avsforum.com to using the Spyder 2 with the HCFR calibration software - i'm assuming this would be the route to go down.
Old 29-10-2009, 5:02 PM   #2
Gordon @ Convergent AV's Avatar
41,388, Level: 49
Points: 41,388, Level: 49 Points: 41,388, Level: 49 Points: 41,388, Level: 49
Activity: 5.4%
Activity: 5.4% Activity: 5.4% Activity: 5.4%
Thanks: Gave 984, Got 1,706
Re: Using a Spyder 2 Express to calibrate projector
Yes you need third party software to get the data from your Spyder in to a form you can understand...then you need to actually know how to use that data to adjust your projector.
HCFR is most home calibrators weapon of choice as it's free.
jagsta (29-10-2009)
