Calibrating my system
Old 27-09-2009, 12:14 PM   #1
2,273, Level: 11
Points: 2,273, Level: 11 Points: 2,273, Level: 11 Points: 2,273, Level: 11
Thanks: Gave 138, Got 54
Hi All, I have set up my new system Onkyo 876, MA RS6;s, Centre and RSFX rears, Pioneer lx6090 but need it setting up properly/calibrating as I am sure it is nothing like as loud as it should be etc which is probably/hopefully down to me. Any sugestions on who I can get to come and set it all up correctly in the Kent area?
Old 16-10-2009, 2:19 PM   #2
855, Level: 6
Points: 855, Level: 6 Points: 855, Level: 6 Points: 855, Level: 6
Thanks: Gave 4, Got 4
Re: Calibrating my system
try this guy
Progressive Audio Visual... Home Cinema and Audio System Custom Installation Tunbridge Wells, Kent
Old 16-10-2009, 2:50 PM   #3
4,466, Level: 15
Points: 4,466, Level: 15 Points: 4,466, Level: 15 Points: 4,466, Level: 15
Thanks: Gave 0, Got 13
Have you tried using the Audessey auto-calibration system on the receiver? It may save substantial costs and you'll know how to use it for future re-calibrations.
