***I wrote the following without reading the OP properly and assumed it was a PZ70 or 80!
It may thus be of absolutely no use at all! But it might still be, which is why I'm leaving it as is****
As no-one else has responded to this I'll have a go, even though like you I am just picking this up through reading and am not a pro.
Originally Posted by spitty Once I figured out that I could only make changes to Normal/Normal setting within the service menu |
Does this mean you are calibrating normal/normal then? But you can change both of these within the service menu on the appropriate page (WB ADJ). The numbered buttons to use are indicated in the menu. BUT beware: as you probably know, even with these properly selected, the picture in and out of the s/m looks different, so you have to take a measurement, go in and make adjustments, then exit the s/m before taking new readings. A bit of a grind.
The upside of your current settings is that you are getting decent gamma, whereas on cinema/warm I struggle to reach 1.95. The downside is that normal is *not* the same as cinema with an offset: it has floating blacks, which drive me mad. (These may may be the reason for the better gamma, though I'm not sure about this--any pointers from anyone else would be welcome.)
Originally Posted by spitty I twiddled the RGB values using the 30%/80% IRE Pluge patterns |
I'm a bit confused--surely you have to measure at every 10 IRE interval to get the data? Or do you mean you were taking continuous measures on these points as you tweaked? That won't work because of the behaviour of the service menu. You have to make an adjustment, exit the s/m, and do another run to see the effects of the tweaks.
Originally Posted by spitty I tried tweaking with the 20% pattern and reducing blue-cent, but I could only make things worse across the entire range.
...Would it be possible for anybody to suggest what I should be concentrating on doing to improve the bottom-end? |
I'm not sure what you mean by blue-cent, but surely the obvious thing would be to lower blue cut a few points and see what happens?
People have also said these probes aren't very accurate at 20 IRE and below, so there may be nothing more to do anyway
...though that's no reason not to give it a go.
