Hi there
First post here so be kind to me
I've just moved to my new home and I'm having a problem with my living room. The room is 23' x 16' x 8'. It's construction is concrete floor - brick / aircrete walls with dabbed on platerboard - plasterboard ceiling under trussed insulated roof.
My floor standing speakers have been with me in several different locations - and have always been fantastic in their low frequency output. So much so that I have had to attentuate them at times. However this new room is a different matter!
However much I boost the low frequency output - to the point of reaching the woofers excursion limit there is just no / very light bass reproduction?!
Having read a little about room acoustics - it would seem I have a problem with reflection and cancellation of the lower frequencies. Currently the room is pretty sparse save for some thin carpet with no underlay - and an old oak frame three piece suite.
I have read that bass traps would reduce the cancellation and allow me to hear the low frq's. However I would like to try some heavy soft furnishing first to see if that has any effect.
My initial question is regards to the carpet underlay. Would anyone be able to advise which would be best for absorbing the low frq's? I've looked at Cloud 9 and simlar PU foam - heavy (130lbs) rubber - and the very thick felt / pure wool type which appear to have the best thermal isolation properties. Wasn't the felt stuff similar to what was used in speaker cabinets to dampen the reflected waves?
Anyway - which is best - PU Foam - Rubber or Felt / Wool?
I'm not bothered about reducing sound transmission or impact noise by the way - the house is detached. Just helping with my bass reproduction.
Thanks!
