Mic Amp for Behringer ECM 8000
Old 15-09-2009, 9:57 AM   #1
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Points: 29,394, Level: 41 Points: 29,394, Level: 41 Points: 29,394, Level: 41
Activity: 25.7%
Activity: 25.7% Activity: 25.7% Activity: 25.7%
Thanks: Gave 324, Got 787
I have a mic from an SMS-1 which I am pretty certain is the Behringer ECM8000. I would like to use it with REW to give a more accurate plot than my RS SPL Meter. This is mostly for subwoofer setup but I may also use it to test/measure other speakers etc.
Can you suggest a Mic Amp 'Good Enough' for this application. I don't want to spend a fortune if it isn't necessary but if I am going for a more accurate result it needs to do the job.
I have been considering the M-Audio Mobile-Pre but it is quite a bit of money and as I already have a soundcard on my motherboard it seems a bit OTT. However if I am to be convinced this is the way to go I don't mind putting my hand in my pocket.
Thanks,
Adam
Old 15-09-2009, 1:19 PM   #2
amioa's Avatar
2,256, Level: 11
Points: 2,256, Level: 11 Points: 2,256, Level: 11 Points: 2,256, Level: 11
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 9, Got 100
Re: Mic Amp for Behringer ECM 8000
you need something with Phantom power, i bought a cheapy and it works very well for me, i will look it up when i get in
Old 15-09-2009, 1:23 PM   #3
Ianfromnotts's Avatar
6,340, Level: 18
Points: 6,340, Level: 18 Points: 6,340, Level: 18 Points: 6,340, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 12, Got 169
xenyx 802 seemed to be the usual recommendation when I last looked - there's a few one ebay right now between £10 and £35 from a quick look
Old 15-09-2009, 3:46 PM   #4
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Activity: 25.7%
Is this the sort of thing? BEHRINGER: MIC800
Adam
Old 15-09-2009, 4:05 PM   #5
6,340, Level: 18
Activity: 3.0%
might be if you can switch this off
dedicated Low Cut filter eliminates unwanted noise, e.g. floor rumble
Old 15-09-2009, 4:15 PM   #6
6,340, Level: 18
Activity: 3.0%
Just checked and as far as I can see it cant be switched out.
Behringer XENYX 802 Premium Mixer | DV247
Put can be had much cheaper on ebay
Old 15-09-2009, 4:29 PM   #7
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Activity: 25.7%
Thanks Ian, I had hoped for something with a few less knobs to keep me out of trouble but if that is the kiddie I'll take a look.
Adam
Old 15-09-2009, 4:45 PM   #8
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Activity: 25.7%
This looks like the sort of simplicity I was hoping for but is it any good/right for the job?
M-AUDIO - Fast Track USB - Record Guitar and Vocals on Your Computer—Complete with Effects
Thanks,
Adam
Old 15-09-2009, 6:03 PM   #9
amioa's Avatar
2,256, Level: 11
Activity: 1.4%
this is what i use:
Behringer Micropower PS400 | Dolphin Music
linked in with Laptop and USB soundcard, chuffing expensive measurement software as well as cheaper, depending on if im doing a room or a large hall.
Old 15-09-2009, 6:46 PM   #10
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Activity: 25.7%
Originally Posted by amioa View Post
this is what i use:
That gets me part way there but I still need a RCA or mini jack to XLR adapter and would be feeding with an unbalanced input. Would that be ok?
Old 15-09-2009, 7:52 PM   #11
amioa's Avatar
2,256, Level: 11
Activity: 1.4%
I plug in to the usb soundcard, with an adaptor to knock it down to small size, the software I use figures out what the input in is and sorts itself out accordingly, i could plug in more if i wanted and it would work it out. You should be the same, cable out from power goes to input on soundcard
Old 15-09-2009, 8:53 PM   #12
4,679, Level: 16
Points: 4,679, Level: 16 Points: 4,679, Level: 16 Points: 4,679, Level: 16
Thanks: Gave 59, Got 142
Blue Microphones Icicle | Dolphin Music
£50 for an all-in-one solution (mic pre to USB with phantom)
Only 1 channel though, so you can't do real frequency response measuring with it, but I don't think REW does that anyway.
Old 18-09-2009, 9:17 AM   #13
4,906, Level: 16
Points: 4,906, Level: 16 Points: 4,906, Level: 16 Points: 4,906, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 12, Got 46
Audiobuddy is very good and is 2 channel:
M-Audio Audio Buddy Dual Mic Preamp and Direct Box with Phantom Power | DV247
Old 18-09-2009, 10:02 AM   #14
Conspicuous Member
AngelEyes's Avatar
29,394, Level: 41
Activity: 25.7%
Most of the solutions suggested are coming in around £60-75 so I am wondering about going the whole hog and getting either of these two but hope someone can clarify:
M-AUDIO - MobilePre USB - USB Bus-Powered Preamp and Audio Interface
This has a built in Soundcard as well as Mic Pre-Amp?
Tascam US-122L, - Online Music Store | Sounds Live
Tascam US122
No built in Soundcard, just a USB powered Pre-Amp?
I like the idea of USB power as it is one less plug and means I can go mobile with it but if it has no Soundcard built in and my laptop has no line in/out does that stuff me anyway?
The cheaper option is the Behringer XENYX 802 but it just seems way to complex for my needs and the XLR in the top would be a pain as I would place it in my Rack/Cupboard whilst in use.
The Tascam seems the simplest and best laid out for me but will it do what I need?
Thanks for your patience.
Adam
