Originally Posted by I-Spy Hi,
Well I'm a bit surprised by these responses "read manufacturer's instructions" is a bit limited really.
There are a number of steps you can take to (a) improve sound quality and (b) reduce sound travelling upstairs. I have 9 speakercraft speakers installed (7 in the lounge, 2 in the kitchen).
If you can use a double-layer of plasterboard on your ceiling go for it. If that's not possible then use some Dynamat Extreme around the speaker hole so that the speaker is well anchored to the dynamat and the plasterboard. Mass and sound dampening are important for in-ceiling speakers. A flimsy ceiling will vibrate and resonate much like your speaker cones are supposed to but, obviously, they will be out-of-phase and basically act as a form of distortion on the sound. You need to cut the dynamat into quarter segments and only about 1cm circumference should be around the edge of the speaker hole that you can see. The rest of it should be folded inside and smoothed out onto the back of the plasterboard.
Next, use double-folded loft insulation in the rafters to either side of the speaker (just shove it down the rafters) and a single unfolder layer taped to the floorboards above just above the speaker position. I use SpaceLoft which is of a better quality than Rockwool.
If you want to experiment then I have found an improvement on 'just' loft insulation by creating a high density wood fibre board/dynamat combination which I've glued to the floorboards above (this can be a bit tricky when you've only got an 11" hole to work through but persevere). I'm still experimenting with this and the Dynamat stuff is too expensive to use for the lounge (just focusing on the kitchen for the moment). Do this step first and then add the loft insulation.
Hope this helps. |
valid pionts and some good fun being had experimenting, but my comment on reading the manual was because some manufacturers have very specific requirements, so 'rtfm' is the best starting point - some speakers require a cavity, some have a cavity built into the box they mount in etc etc.
Dynomat is a damping sheet primarily designed for use in motorvehicles, we did extensive tests with dynomat for acoustic enclosures and found that it worked best on sheet metal(as it was designed) but didnt really justify its price, which would push me look at using MLV, which should be cheaper than dynomat, but not necessarily better to work with.
the other option is to buy acoustic hoods which are designed to sit over standard speakers in ceilings, they are used everywhere from offices to penthouse flats (but with varying degrees of success)
