DVE (Digital Video Essentials)
Old 14-08-2009, 5:16 PM   #1
5,945, Level: 18
Points: 5,945, Level: 18 Points: 5,945, Level: 18 Points: 5,945, Level: 18
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 238, Got 12
On Blu-Ray or DVD? Is either one better than the other? Or are they the same but on different format??
Old 14-08-2009, 5:26 PM   #2
bladedripper's Avatar
7,920, Level: 21
Points: 7,920, Level: 21 Points: 7,920, Level: 21 Points: 7,920, Level: 21
Activity: 10.5%
Activity: 10.5% Activity: 10.5% Activity: 10.5%
Thanks: Gave 190, Got 386
Re: DVE (Digital Video Essentials)
If you have a ps3 and the blu-ray version id use that.
TEROKNOR (14-08-2009)
Old 14-08-2009, 5:35 PM   #3
andy1249's Avatar
11,175, Level: 25
Points: 11,175, Level: 25 Points: 11,175, Level: 25 Points: 11,175, Level: 25
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 46, Got 909
The blu ray version has been slated online for its over saturated colours and overall bad presentation.
http://www.amazon.co.uk/Digital-Vide...0271385&sr=8-4
I can verify that , I have both and I wouldnt use any of those test cards on the blu ray to correct my TV , they dont look trustworthy.
The Audio setup section is still excellent though , exactly the same as the DVD.
I would stick with the DVD version.
Old 14-08-2009, 5:38 PM   #4
Fatwaz's Avatar
5,364, Level: 17
Points: 5,364, Level: 17 Points: 5,364, Level: 17 Points: 5,364, Level: 17
Thanks: Gave 21, Got 284
it makes no difference which one you use they should both give you the same result.
Old 14-08-2009, 6:07 PM   #5
5,945, Level: 18
Activity: 1.7%
Yep My PS3 is my only Blu-Ray player at the moment. I can use it to do both my 32" LCD and 42" Plasma.
Old 14-08-2009, 6:09 PM   #6
Will Scarlet's Avatar
4,858, Level: 16
Points: 4,858, Level: 16 Points: 4,858, Level: 16 Points: 4,858, Level: 16
Thanks: Gave 99, Got 191
The Blu-ray version is fine, a little awkward to navigate but does exactly what it says on the tin.
Old 14-08-2009, 6:43 PM   #7
Silver Serpent's Avatar
50,208, Level: 54
Points: 50,208, Level: 54 Points: 50,208, Level: 54 Points: 50,208, Level: 54
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 221, Got 422
You can download and burn a free calibration disc here for use with your PS3:
AVS HD 709 - Blu-ray, HD DVD, & MP4 Calibration - AVS Forum
AVCHD
Old 14-08-2009, 6:54 PM   #8
5,945, Level: 18
Activity: 1.7%
Thoughts on this?????
Home Theater: A Great Picture in Five Minutes Flat
Old 14-08-2009, 7:03 PM   #9
50,208, Level: 54
Activity: 1.5%
The link I provided with the Free Download will have all the patterns you require for a basic calibration, and more.
It comes highly recommended.
Old 14-08-2009, 7:07 PM   #10
5,945, Level: 18
Activity: 1.7%
Can it be burned onto a normal disc and played in a DVD and PS3. Are there instructions too. Dunce here!!!
Old 14-08-2009, 7:14 PM   #11
50,208, Level: 54
Activity: 1.5%
Burned to a blank DVD and can only be played in your PS3 (BluRay Player).
There is a PDF Pattern Manual download available.
All the information you need is on the page I provided the link to.
Old 14-08-2009, 7:21 PM   #12
5,945, Level: 18
Activity: 1.7%
Damn!!!! Only got CD-RW's!!!!! and a CD rewriter!!
Old 14-08-2009, 7:26 PM   #13
50,208, Level: 54
Activity: 1.5%
Why not just get DVE BluRay then:
Digital Video Essentials: HD Basics Blu-ray - Sendit.com
There is nothing at all wrong with that for a basic calibration.
The Spears & Munsil disc is another you could coniser, but it's more expensive:
Spears and Munsil High Definition Benchmark Blu-ray Disc
You could always get the basic DVE version too which will do your PS3 and DVD Player:
http://www.sendit.com/sendit/81202.product
Old 14-08-2009, 7:30 PM   #14
andy1249's Avatar
11,175, Level: 25
Activity: 18.6%
Maybe someone can tell me whats going on then ,
The versions I have are
DVD Avia II
Avia, Vol. 2: Guide to Home Theater DVD 2007 Region 1 US Import NTSC: Amazon.co.uk: Artist Not Provided: DVD
Blue ray DVE essentials
Digital Video Essentials - HD Basics Blu-ray 2008: Amazon.co.uk: Sam Dalton, Joe Kane: DVD
I have a number of blue ray players , PS3 , BD35 and an LG drive from the HTPC , the color bars in the picture at the bottom all look very similar on my Panny PZ80 and are way more saturated than the DVD version.
The DVD looks the same on all players ( not the BD35 , it wont play it ! ) but I have a Pioneer DVD player and it looks the same on that as well as the PC etc.
I dont know which one to trust , so Im not adjusting my TV or players to either , I suspect the blu ray as other people have said the same.
I did however , set up my sub with a Radio shack meter and this procedure using the test tones on the disk , fantastic results , so worth the money regardless. All said and done thats what I bought the discs for anyway.
How To Set Up a Subwoofer (or Subwoofers) for Home Theater: BigPictureBigSound
Old 14-08-2009, 7:50 PM   #15
Fatwaz's Avatar
5,364, Level: 17
mate check you pm's i'll send you both on a dvd
Old 14-08-2009, 11:16 PM   #16
33,073, Level: 44
Points: 33,073, Level: 44 Points: 33,073, Level: 44 Points: 33,073, Level: 44
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 286, Got 1,333
DVD Avia II
I'm not a expert here and can't really give a full explanation or even know if this is what is causing your problem but SD (the DVD) and HD (Bluray) use different color spaces (SD REC 601 and HD is REC 709). Hopefully a calibrator will be able to explain if this is the reason you see the differences.
Old 18-08-2009, 4:29 PM   #17
johnscarlet's Avatar
18,900, Level: 33
Points: 18,900, Level: 33 Points: 18,900, Level: 33 Points: 18,900, Level: 33
Activity: 19.9%
Activity: 19.9% Activity: 19.9% Activity: 19.9%
Thanks: Gave 225, Got 1,025
If anyone had the MP4 Patterns Manual PDF? You have to be registered to download it
Old 18-08-2009, 5:14 PM   #18
Avi Avi is offline
25,178, Level: 38
Points: 25,178, Level: 38 Points: 25,178, Level: 38 Points: 25,178, Level: 38
Activity: 34.1%
Activity: 34.1% Activity: 34.1% Activity: 34.1%
Thanks: Gave 424, Got 1,748
DVD Avia II
The colour will be determined by your displays colour gamut and you can't accurately assess this without proper tools. To adjust the primary, secondary colour saturation and luminance your display also needs to have the appropriate adjustments for these but many don't.
Whist DVE and AVIA may have patterns they don't not provide the tools necessary to asses and set colour properly so you can't really trust either.
AVI
Old 18-08-2009, 8:57 PM   #19
KMO KMO is offline
6,228, Level: 18
Points: 6,228, Level: 18 Points: 6,228, Level: 18 Points: 6,228, Level: 18
Thanks: Gave 2, Got 57
I've just been going over DVE (PAL version) with an HDMI analyser (because I don't trust stuff either), and I can report that all the 100% and 75% colour bars, and all the grey fields, are within 1 unit of the correct numbers when output by my players with picture controls set to standard - so less than 0.5% error.
There is a complication in that SDTV and HDTV use different RGB<->YCbCr matrices - this means that an sort of SD->HD upscaler has to perform a fairly subtle transformation on the YCbCr values on the disc, if it's set to output YCbCr over HDMI. Some devices may get this wrong, leading to somewhat dippy colours. My kit gets it right, thank goodness - the transformed HDTV YCbCr values are correctly transformed.
There's a more minor issue in that SDTV and HDTV also use a slightly different colour of green. But that's a very subtle issue, and upscaling kit doesn't generally attempt to correct for that, but displays sometimes do. That means you may get very slightly different colours from direct SD input to a TV and upscaled SD input to a TV, if the TV uses different primaries for SD and HD input. That effect would be very subtle though.
I don't think any of this applies to you though - you may just be comparing 75% and 100% (intensity) colour bars. That's not a saturation difference, it's a brightness difference. DVE has both, tucked away in the reference section - see if you can find the 100% version, and compare that to Avia. (I forget whether AVI has 100% or 75%).
Old 20-08-2009, 9:08 AM   #20
Avi Avi is offline
25,178, Level: 38
Activity: 34.1%
I think the problem for the OP is he doesn't have an accurate benchmark to assess colour. Without establishing this it really isn't possible to use AVIA or DVE to assess colour accuracy.
AVI
