Contecting Sega To LCD
Old 10-11-2009, 2:24 PM   #1
simonjanda's Avatar
1,783, Level: 9
Points: 1,783, Level: 9 Points: 1,783, Level: 9 Points: 1,783, Level: 9
Thanks: Gave 1, Got 9
Hiya
I have a Sega MegaDrive 1 with the Megas CD.
With my old CRT TV I had made a cable to connect from the Sega Din out socket to the TV BNC in socket.
I now have a LCD TV with every connection under the sun but BNC.
I connected the Sega via the Coaxil but the picture quality is pants - real poor.
Is there a cable available or does anyone know how to make a cable to connect from the Din Socket to a scart or what options are available ?
Any suggestions would be appreciated.
Old 12-11-2009, 1:25 AM   #2
cas398's Avatar
6,038, Level: 18
Points: 6,038, Level: 18 Points: 6,038, Level: 18 Points: 6,038, Level: 18
Thanks: Gave 201, Got 192
Re: Contecting Sega To LCD
Not sure myself but did a bit of digging (was curious anyway).
Sega Megadrive 1 RGB SCART cable TV lead 2 METRES on eBay (end time 08-Dec-09 13:37:17 GMT)
Also believe you can DIY it:
mmmonkey Master System 1 and Megadrive 1 Scart Lead
Hope that helps a bit.
Old 12-11-2009, 7:27 AM   #3
simonjanda's Avatar
1,783, Level: 9
Hiya
Thanks for the info - much appreciated.
They are still selling these on ebay (your first link) which I think I'll buy one.
The option of making one with all those resisters looked a bit daunting !!
Thankyou for looking in to this for me.
Old 12-11-2009, 10:01 AM   #4
2,137, Level: 10
Points: 2,137, Level: 10 Points: 2,137, Level: 10 Points: 2,137, Level: 10
Thanks: Gave 2, Got 14
I bought one of those cables from ebay, it works great!
But be aware if you want stereo sound you will have to get a cable with an extra jack to plug into your Megadrive's headphone socket.
Megadrive Genesis 1 STEREO RGB SCART cable TV lead NEW! on eBay (end time 21-Nov-09 03:07:36 GMT)
Not quite as neat but it works well. Is worth it for the stereo sound IMO.
