Which Energy Monitor?
Old 07-05-2009, 9:34 PM   #1
majorstare's Avatar
5,564, Level: 17
Points: 5,564, Level: 17 Points: 5,564, Level: 17 Points: 5,564, Level: 17
Thanks: Gave 16, Got 10
Question Which Energy Monitor?
Having a look round the net, are the energy sensors all pretty much just as relaible?
Owl, Efergy, EON, Eco-eye etc?
Old 08-05-2009, 7:36 PM   #2
4,003, Level: 14
Points: 4,003, Level: 14 Points: 4,003, Level: 14 Points: 4,003, Level: 14
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 10, Got 20
Re: Which Energy Monitor?
I'm guessing not many will have used more than one manufacturer's product and all I can say is I have had the Efergy model for around 18 months - it's worked flawlessly and it has helped me save over 30% off my electricity bills.
I will say that these monitors are fairly in accurate - I have checked the usage shown by the energy meter and compared to my meter - it's about 20% out (low). I am assuming most manufacturers will be similar as the technology will be the same/similar. This doesn't really matter as I found it was useful for simply understanding where the energy was being used....
Hop that's of some help.
Old 09-05-2009, 7:14 PM   #3
IronGiant's Avatar
25,198, Level: 38
Points: 25,198, Level: 38 Points: 25,198, Level: 38 Points: 25,198, Level: 38
Activity: 28.7%
Activity: 28.7% Activity: 28.7% Activity: 28.7%
Thanks: Gave 2,342, Got 4,990
I have the efergy one and am really happy with it. I did have a problem in that after I changed the battery in the main unit it couldn't detect the sensor any more. I emailed them about it and got a reply within a few hours as to what to do. You could argue that it would have been better not to have the problem in the first place, but I was pleased to see it demonstrated customer services/tech support are on the ball.
Dave
Old 29-05-2009, 12:14 PM   #4
3,874, Level: 14
Points: 3,874, Level: 14 Points: 3,874, Level: 14 Points: 3,874, Level: 14
Thanks: Gave 8, Got 16
i'm interested in one of these however i'm wondering if it will work on a tariff which is like:
first 200kWh in a quarter is one rate and after that its a lower rate.
this is not E7 though. Although i used to be on e7 and had the meter changed i still have two cables that come out of the main box into my meter and then two cables come out of the meter into my fuse box.
Would this mean I would need two sensors one on each cable before going into the meter?
Old 29-05-2009, 2:13 PM   #5
4,003, Level: 14
Activity: 2.1%
The original efergy one I have will not give you the correct price for your overall electricity use with a two tier pricing system.
I would suggest that the cost is not really that useful because what you want to know is WHERE your energy is being used - find that out - and change the way you use those appliances or change to more efficient appliances (going from an old fridgefreezer to an A++ one saved us 25%), that's how you'll save money.
At the end of the day, you need to know what the energy you use a day is (i.e. kWh) if you reduce this number you'll reduce your costs however they are calculated by the supplier - and all suppliers are different...sorry if I am pointing out the obvious!
Aweb (29-05-2009)
Old 29-05-2009, 9:01 PM   #6
3,874, Level: 14
thanks! that actually explains how better to use the device rather than try and use it to verify my bill
Old 30-05-2009, 5:59 PM   #7
Illustrious Member
Azzin's Avatar
54,550, Level: 57
Points: 54,550, Level: 57 Points: 54,550, Level: 57 Points: 54,550, Level: 57
Activity: 57.4%
Activity: 57.4% Activity: 57.4% Activity: 57.4%
Thanks: Gave 4,006, Got 1,323
Lightbulb Re: Which Energy Monitor?
Just seen an advert on the TV for tomorrow's Sunday People and they are giving one away for free (even the postage is free the ad said).
