Originally Posted by t72bogie not many people switch em off...and with the old linear type it was even worse (the big heavy brick rather than the small light mobile phone type ones) so the State of California banned the old type a couple of years back as they figured out, it would save hundreds of megawatts per year.
This has forced consumer electronic manufacturers to move to the switched type and in the process saving about 1/10th of the standby power of such devices |
which is fine, but there will still be a lot of the old ones out there.
the next stage is the EU broadband guys are trying to get modem/router manufacturers to have low power modes in their boxes too, to get them down from like 15w to <1w ..as you can imagine, with 12 million broadband users in the Uk alone, it should make quite a difference
Lots of routers out there and lots still in the shops to be sold, so even if they banned routers that have high power, it will take years before it makes much difference. Most routers will last for years, I have a router here that is 7 years old and still works fine if I needed to use it, my speedtouch is 3 years old and works perfect. Routers don't go wrong that often and are only replaced if someone changes ISp and use a the ISP router, like Bt or they want another feature.
The new N routers have not really made a impact, I only know one person that got a Nrouter and that is only because they have just gone wireless. Every one else I know is still using old routers thay have had for a while.
Anyway at the moment I don't think there is any way to get a router to go into a low power mode and then come out of it without some human help.
the new Bt router have some sort of low power, but you still need to press a button to it working in normal mode.
Low power and wireless is not ideal and will not work.
Anyway the E.u can go to hell.
anyway, I dont worry personally about the small switched ones being plugged ...but those big old power brick type ones ...well some of those are consuming nearly as much power just plugged into the wall, even without their device charging so make sure to switch the socket off at the mains or unplug those for sure |
The only big power supply I have is for my scanner, all the others are smaller newer types, so they use less power.
But you think all these people who have power supplies plugged in, no matter if it using 1 watt, that can stil create a lot of power. 1,000 people would give you a 1,000 watts and what do that convert to in CO2 emmisions?
How many are using cordless phones in their houses? I have four, just done a test, each charging unit uses 2 watts, no matter if there is a phone in there or not, I am pretty sure that the main unit will use more.
this is what I don't undertsand, we are all slowly being forced to use Low energy bulbs and yet nothing is done about power that is wasted by other means.
