Energy saving Light Bulbs
Old 25-09-2008, 8:38 AM   #31
4,003, Level: 14
Points: 4,003, Level: 14 Points: 4,003, Level: 14 Points: 4,003, Level: 14
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
Thanks: Gave 10, Got 20
Re: Energy saving Light Bulbs
please supply a reference or data for your statement...
Old 25-09-2008, 9:00 AM   #32
4,003, Level: 14
Activity: 2.1%
Originally Posted by Nic Rhodes View Post
...just re-read your post - I obviously didn't read it properly. I've not heard of any brighter luxeons than the 5W you mention, but I'll keep a look out and post here if any turn up in the future.
R
Old 25-09-2008, 10:18 AM   #33
9,281, Level: 23
Points: 9,281, Level: 23 Points: 9,281, Level: 23 Points: 9,281, Level: 23
Thanks: Gave 38, Got 65
From experiance that a florenace light can give me headace's even watching the tv as your eye's become more sensative to the strob effect of the light, including tv's .
Old 25-09-2008, 2:14 PM   #34
4,003, Level: 14
Activity: 2.1%
OK, fair enough, but these are completely different types of light. Luxeons are LED based and not fluorescent based.
I've also not heard of anyone else having such problems (not that I am saying there are none)...Do you know if you are particularly sensitive to any forms of strobing?
Old 25-09-2008, 3:26 PM   #35
Chrisoldinho's Avatar
11,382, Level: 25
Points: 11,382, Level: 25 Points: 11,382, Level: 25 Points: 11,382, Level: 25
Thanks: Gave 374, Got 270
Right, well i've now refitted my entire upstairs (bar 1 room) with energy saving light bulbs and i'm mighty impressed.
The light starts off about 20% dimmer a conventional bulb, but within a minute it's actually brighter than a normal bulb i'd say by about 10%. The light emitted from the upstairs bulbs is very similar to normal bulbs and exactly what you would expect.
All in all i'm really pleased.
I'm looking for a dimmable energy saving light bulb now but cannot find one sub £8 which I think will negate any cost saving for me, so i'm not changing this one for the time being. If anyone can find one cheaper please let me know, i'm looking for an 11W Bayonet Cap Energy Saver.
Now for downstairs, i'm not quite as happy here...
As we have an open plan living/dining area it made sense to get some energy saving bulbs as we're in here here the most. As we use "candle" lights I opted for "ENERGY SAVING CANDLE 7w LIGHT BULB" from eBay.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=360087238984
Unfortunately the light produced is "Bright White" and a bit too glarey, it also doesn't suit the room that well (but that's not the candle's fault), also I was slightly disappointed with the size, i'm sure for some people it would be fine and the light may even be to their liking (almost xenon).
If anyone can find me some energy saving equivalent size of conventional candle bulb lights then please post a link, i'm looking for 40w equivalents that are screw in's and produce a normal warm light and not xenon/stadium light white.
Chris.
Old 01-10-2008, 7:29 AM   #36
11,382, Level: 25
UPDATE
Bought 3 Lamp Bulbs from Sainsbury's on my way home the other night, the light is much warmer than the previous set, cost was about £2.50 per bulb but they are much smaller. Not sure i'll ever see the cost saving benefit as in total i've spent about £15 getting the right lights now but kay sara.
Still looking for a cheap dimmable energy saver then that's every light I use on a daily basis in my home done bar the kitchen.
Old 01-10-2008, 9:28 AM   #37
4,003, Level: 14
Activity: 2.1%
I think you'll find you get your money back very quickly, especially with the cost of electricity at around £0.19 / kWhr. Depending on usage and the difference between the old and new bulb's power requirements, it could be just a few months to break even.
Chrisoldinho (02-10-2008)
Old 01-10-2008, 9:55 AM   #38
4,755, Level: 16
Points: 4,755, Level: 16 Points: 4,755, Level: 16 Points: 4,755, Level: 16
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 16, Got 258
Needed one no bigger than a conventional bulb for inside a restricted glass shade. Found in Tesco, GE 12W exactly the right size for £2.38.
In Asda since, same bulb at £4.99
Old 03-10-2008, 12:32 PM   #39
7,683, Level: 20
Points: 7,683, Level: 20 Points: 7,683, Level: 20 Points: 7,683, Level: 20
Thanks: Gave 55, Got 82
I am concerned that proper lightbulbs are becoming harder to find, and I am also worried that some silly law might come out to take them all off the shelf. Therefore, I managed to source 200 60W proper lamps for just 14p each, bargain
Old 04-10-2008, 8:38 PM   #40
5,501, Level: 17
Points: 5,501, Level: 17 Points: 5,501, Level: 17 Points: 5,501, Level: 17
Thanks: Gave 154, Got 73
I managed to pick up x5 Philips 14watt (75 watt type i think) for only 50p for all of them from Morrisons
Only when i got home did i notice that they was the screw type fitting and no 2 pin twist fit bulb that most lights are
Old 06-10-2008, 11:39 AM   #41
4,003, Level: 14
Activity: 2.1%
...not such a bargain when you consider the cost of the energy they use!
Old 07-10-2008, 9:51 AM   #42
11,382, Level: 25
Being completely honest here I was a sceptic of energy saving bulbs and I didn't believe the hype. I thought they weren't going to be as bright/wrong colour and may take ages to warm up.
All I can say is how wrong I was.
Literally they are the same size as normal bulbs, they cost 50p these days, they use 10% of the power and the light that they emit is actually more after about 1 minute of use and about 80% of a conventional bulb during the 1st minute (no biggy, you can't even really notice it much, in fact it's easier on the eyes).
So for any none believers out there, go and spend 50p of your hard earned on one and be amazed, I guarentee the newest ones are extremely good.
Old 07-10-2008, 9:57 AM   #43
2,143, Level: 10
Points: 2,143, Level: 10 Points: 2,143, Level: 10 Points: 2,143, Level: 10
Thanks: Gave 21, Got 11
They do have the '2-pin twist fit' too, picked up a few the other day and they are pretty good (for 10p each!)
Old 08-10-2008, 8:26 AM   #44
7,459, Level: 20
Points: 7,459, Level: 20 Points: 7,459, Level: 20 Points: 7,459, Level: 20
Thanks: Gave 2, Got 12
Sounds good to me. It is annoying me that we are being told what to buy and what not to buy. I got a load of normal bulbs which should last for a few years. I got loads of 60 watts, but they are mainly for the downstairs loo and the stairs. I also got a load of 100watt bulbs, for other rooms.
I have to get some more just to make sure I have enough so when this dictator government decide they know what is best for us decide to ban them from sale.
At the moment there will only be a recommendation not to sell normal bulbs, but how long wil it be before we will not be able to get any?
thank goodness for Pound stretchers.
Old 08-10-2008, 8:28 AM   #45
7,459, Level: 20
Been there, done that, still find they are no good. I don't know where you found these bulbs for %0p, but around here, they are 99p or more.
Maybe one day when LEd bulbs get beter and they have better light I will change my mind, but I am staying with my normal bulbs,
Old 08-10-2008, 11:43 AM   #46
14,506, Level: 29
Points: 14,506, Level: 29 Points: 14,506, Level: 29 Points: 14,506, Level: 29
Thanks: Gave 138, Got 252
I am concerned that proper lightbulbs are becoming harder to find, and I am also worried that some silly law might come out...
as in "....of physics"? Cos it already has.
Old 08-10-2008, 3:08 PM   #47
2,300, Level: 11
Points: 2,300, Level: 11 Points: 2,300, Level: 11 Points: 2,300, Level: 11
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 20, Got 269
If you're wondering where the interference on your radio is coming from.........try turning the light off.
Old 08-10-2008, 4:09 PM   #48
Phil57's Avatar
3,207, Level: 13
Points: 3,207, Level: 13 Points: 3,207, Level: 13 Points: 3,207, Level: 13
Thanks: Gave 600, Got 310
Maybe one day when LEd bulbs get better and they have better light I will change my mind, but I am staying with my normal bulbs,
Obviously not shopping at Morrisons then.
Morrisons sell energy saving bulbs for 39p each and have done so for some time, they still do, but are also currently running a promotion and are now selling them five for 50p.
Old 08-10-2008, 7:08 PM   #49
7,459, Level: 20
no it have not, the government have recommended that shops stop selling them, but they not been forced. I think that cheap shops like Pound Stretchers will continue for a while.
Why should we be forced anyway, what the hell have it got to do with our government or any one else for that matter what bulb we use?
Maybe they should ban those 500watt outside halogen bulbs first.
Old 08-10-2008, 7:31 PM   #50
7,459, Level: 20
I don't shop a Morrisons that often and if I do I normally go in, get what I want and get out, but then I do that with all supermarkets when I am shopping and I work for one.
I came home this evening and saw a leaflet in our local free paper about them. Philips, with enforced by e-on stuck on them.
Still not buying any,
Old 08-10-2008, 10:52 PM   #51
14,506, Level: 29
The point I was trying to make is that the Laws of Physics rather than some "silly" law of the land are driving this, whether people who do not understand like it or not.
What it has got to do with our Govt is that they are elected to look after us and we will all suffer a lot economically if something is not done about the selfish few.
Old 09-10-2008, 9:26 AM   #52
7,459, Level: 20
supermarkets and DIYs will stop selling normal bulbs, but you will always have places like Pound strecher that will continue doing so unless it does become illegal.
Selfish few? Tell me how much equipment in audio, video and computers have you got? think about how much power that lot uses.
I have a 42 inch Plasma that take over 300watts of power when on, a DVD recorder, a TUTV box, a Wii, a PS3, a 5.1 surround amp ( cheap tacky thing, but it will do for a while). then there is my hi-fi. All of these are on standby 24 hours a day. then my computer upstairs is on more than it is off. My laptop is never off. then you got the small things like chargers for dect phones, I got 4 of them and then the router.
That is only in my house and yes I do have more electronics than some people.
My neighbour have three Sky boxes, no doubt three T.vs in standby, and a few DVd players, plus a LCd T.V which takes a fair bit of power when it is on.
I bet I could go down the road and ask every single person if they leave their gadgets on in standby and I bet 99% of the people do and there are a lot of people on my side of the road that have Sky, and no doubt on the other side, but their dish would be around the back of the house.
so I don't think that me or a few other people not using low energy bulbs is going to make a lot of difference.
Still got nothing to do with the government and they are hypocrites when they waste more energy than I do.
I use normal bulbs, because I don't like Low energy ones, I am not being forced into using low energy, and I don't care what this government or some greenies that want us to live in caves say.
Old 09-10-2008, 9:50 AM   #53
Illustrious Member
48,568, Level: 53
Points: 48,568, Level: 53 Points: 48,568, Level: 53 Points: 48,568, Level: 53
Thanks: Gave 884, Got 1,285
no wonder we have a problem.
Old 09-10-2008, 10:34 AM   #54
Jeff's Avatar
18,787, Level: 33
Points: 18,787, Level: 33 Points: 18,787, Level: 33 Points: 18,787, Level: 33
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 75, Got 249
It would be nice if these low energy lights worked, the spots I have in the bathroom take minutes to get to their full brightness.
Old 09-10-2008, 12:40 PM   #55
14,506, Level: 29
It's not the government or "greenies". It's scientists. If you think you know better, that's up to you.
I turn all my stuff off when I'm not using it - I have better things to do than go to work just so I can pay energy bills I don't need to.
Old 09-10-2008, 4:37 PM   #56
johntheexpat's Avatar
2,826, Level: 12
Points: 2,826, Level: 12 Points: 2,826, Level: 12 Points: 2,826, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 623, Got 662
I know I shouldn't because if you read the report the risk is vanishingly small, but............
UV light fear over 'green' bulbs
Still, if you do end up with a warm rosy glow, you'll be able to turn the heating down
Old 09-10-2008, 6:02 PM   #57
bjd bjd is offline
5,847, Level: 18
Points: 5,847, Level: 18 Points: 5,847, Level: 18 Points: 5,847, Level: 18
Thanks: Gave 101, Got 139
You know, I wondered why I had such a "healthy" tan during such a dismal summer.
Old 10-10-2008, 12:29 AM   #58
7,459, Level: 20
who have a problem?
Old 10-10-2008, 12:33 AM   #59
7,459, Level: 20
so the scientists know better than me about my dislike of low energey bulbs? I don't think so. As for scientists being right, they have been wrong about many things before. Even evolution is still only a theory
The upstairs comp is normally in use, even if I am not by it, the laptop is just useful to be left on and to be honest take very little power. The other stuff left on standby is because it is easier and less hassle.
Old 10-10-2008, 12:35 AM   #60
7,459, Level: 20
Fantastic, it shows that nothing is known about these bulbs at all. Fuirst the mercury and now a UV light fear. Why are these things not checked out first , before they try and force them on us?
