Originally Posted by robhowell You appear to be using those GU10's with many individual LEDs mounted inside. I use the Luxeon based GU10 which contain a single high output device (obtained from ebay).
Mine are used in the bathroom which has little natural light and are on and off many, many times a day and none have failed in over a year. One reason the multi LED types you have might be inherently less reliable is because of the number of joints required - two for each LED - rather then just two overall for the Luxeons. Just a thought.
Try the Luxeon based ones - so far so good. |
you could be right, with a dozen or more individual LEDs I guess there is simply more opportunity for failure.
However, the single luxeon types are more expensive.
From a cost point of view it is hard to justify a £10 odd LED GU10 over a 50p regular one...
If you can be confident you can fit them once and forget I suppose it would be worth it.
However, I do like being able to leave lights on (in certain places) without feeling guilty about it...
