A new challenge to the validity of historic CO2 levels
| | Post Reply |
| | #1 |
| Member | A new challenge to the validity of historic CO2 levels Advertisement Want to Advertise?
Perhaps current levels are not so high after all ? http://homepage.ntlworld.com/jdrake/...s_report_1.pdf |
| Quote |
| | #2 |
| Prominent Member | Re: A new challenge to the validity of historic CO2 levels
How does this help us reduce our carbon footprint? Again you appear to misunderstand the nature of the current problem. It's not that global temps or CO2 levels haven't been as high prehistorically. It's that we don't want global CO2 levels (and hence temps) to continue to rise to levels seen in prehistory, but over the next few decades. |
| Quote |
| | #3 |
Anyone know which peer reviewed journal this appeared it, if indeed it has appeared anywhere?
| Quote |
| | #4 | |
| New Member | Re: A new challenge to the validity of historic CO2 levels Quote:
| Quote |
| | #5 | |
| Prominent Member | Re: A new challenge to the validity of historic CO2 levels Quote:
1/ It was shown many years ago that CO2 levels are one of many drivers of global temperature (in addition to being driven by global temperature) 2/ Man is adding significant quantities of CO2 to the atmosphere 3/ Global temperatures are going up To suggest that CO2 does not cause global temp rises or that man's CO2 output is somehow irrelevant opposes even the views of the majority of sceptics. | |
| Quote |
| | #6 | |
Absolutely agree with this. The world will be a much better place with oil (for reasons that have nothing to do with the theory of AGW). Absolutely agree with this. The area of contention is the rate of increase and the causes behind the increase (there is likely to be more than one cause). So despite our differences in other posts/threads, we actually have a lot in common | |
| Quote |
| | #7 | ||
http://nationalacademies.org/onpi/06072005.pdf Quote:
| Quote |
| | #8 | ||
I will also credit you for acknowledging that CO2 levels are one of many drivers of global temperature. So you and I now agree on all three original points | ||
| Quote |
| | #9 | |
snip "The existence of greenhouse gases in the atmosphere is vital to life on Earth – in their absence average temperatures would be about 30 centigrade degrees lower than they are today." /snip I would have thought average temperatures would be much more extreme and volatile without greenhouse gases. Considering the signatories in the document, I think I must have missed something . . . | |
| Quote |
| | #10 | |
| Quote |
| | #11 | |
I would imagine an atmosphere without greenhouse gasses would effectively render the planet hostile to all life, with temperatures swinging from extremely high when facing the sun, to extremely cold when facing away from the sun. Would this be a more accurate representation of the realities of no greenhouse gas? Last edited by splatz; 12-06-2008 at 4:24 PM. Reason: Typo | |
| Quote |
| | #12 | |
I would imagine an atmosphere without greenhouse gasses would effectively render the planet hostile to all life, with temperatures swinging from extremely high when facing the sun, to extremely cold when facing away from the sun. Would this be a more accurate representation of the realities of no greenhouse gas?[/QUOTE] I'm afraid I don't know. An atmosphere of just Oxygen and Nitrogen on its own will keep in a fair amount of heat during the night and the desert gets cold because the sand doesn't keep the heat overnight as well as (moist) dirt. | |
| Quote |
| | #13 | |
![]() How do you calculate average overall global temperature? I tried searching for a definition of the technique and failed ![]() I suppose a statelite far enough out could provide an average reading over a wide area, but I think you would get a different reading if the satelite was positioned over the equator compared to a satelite position above the poles. I guess you could average the two. Another technique would be to take readings from ground based stations around the globe, but how would you use that data to create the average global temperature? For example, would you just measure the highest temperature at each site, then average out all the readings? Or would you measure min and max to find the average for the day for each site, then average out all the readings (an average of an average)? But what day of the year do you choose for all your readings? Do you take min max average every day and average that out for the year, then average out all the readings (an average of an average of and average)? And how do you factor out bias? For example, only about 30% of the surface is land so we have to assume that the large majority of temperature stations are going to be on land. Most of those stations are located in the northern hemisphere (because the northern hemisphere contains twice as much land mass as the sourthern hemisphere) and many are near population centers (urban heating effect). All of a sudden it doesn't look like an easy thing to calculate to me (my head hurts )Perhaps the easier question to answer is the last part of your post ![]() So, anyone want to chime in on whether an atmosphere without greenhouse gases would or could retain enough heat? Personally I would think not because it is the greenhouse gases that trap the heat (the most abundant being water vapour), but I have to defer to others more qualified than me. Last edited by splatz; 12-06-2008 at 8:26 PM. Reason: typo | |
| Quote |
| | #14 | |
This paper here questions the greenhouse and radiative forcing theory. This paper here suggests that anthropogenic CO2 may not be as relevant as the alarmists would have us believe and further suggests that any warming during the 20th century was part of the natural warming cycle following the Little Ice Age. 2. Mankind is responsible for only 3-4% of total global carbon cycle CO2 emissions. The atmosphere contains roughly 750 gigatons of carbon dioxide, of which only about 6 gigatons are attributable to fossil fuel burning and cement production. The significance of that 3-4% is open to debate. 3. Global temperatures are not currently displaying a rising trend. Indeed, RSS global land and temperature data for May 2008 show an anomaly of -0.083 degrees in the January 1979-April 2008 series and the HadCRUT data will likely come in at about +0.1 degree. The 2002-2008 global temperature trend is showing a distinct fall. Your point being that I am some sort of extremist?!!! Doesn't phase me one iota. I believe what I believe. Whether my beliefs concur or not with those of others is purely coincidental. | |
| Quote |
| | #15 | ||||||||
Another example of how the only way that the sceptics can make points is to misstate the Climate Change argument: Quote:
And this paper too ignores the lag between increasing CO2 and higher temperatures. Your greenhouse gets warmer later in the day, not as soon as the sun comes out. Quote:
I suspect that you are confusing balance sheet and profit and loss. So 750 gigatons (bablance sheet) accounts for, say, 375ppm and 6 gigatons then accounts for 3ppm ADDED EVERY YEAR. Quote:
You not only disagree with the vast majority of the worlds' educated, trained and experienced scientists, you disagree with the vast majority of the sceptics too. | ||||||||
| Quote |
| | #16 | |
Since it radiates the same amount, its temperature obviously isn't raised by carbon dioxide absorbing some infrared - for CO2 simply releases that energy at the same pace So the earth reaches a steady temperature and then the Earth radiates as much energy as it absorbs, since loss of energy through radiation increases with temperature until the amount absorbed by the planet, equals the amount irradiated out to space, thus a nice steady state of average temperature is reached. I can't see how that correlates with previous known variations in the Global Average Temperature? Unless the Sun became more active, during times of higher temperature and less active during cold periods. Any evidence for this? | |
| Quote |
| | #17 |
From the same link: "Why isn't anyone else shouting from the rooftops about the self-evident absurdity of the IPCC model?" Probably because we are cringing with embarrassment at the thought of having wasted time reading this 'paper'/blog/waste of time and energy. |
| Quote |
| | #18 | ||||||||||
The scientist is talking about atmospherics. Quote:
Glad you agree Quote:
"There is no relationship between carbon dioxide produced by industry and climate change," he said. Professor Plimer said the scientific community had not reached any kind of consensus that carbon dioxide causes global warming. Quote:
No I don’t. I think thousands agree with me. | ||||||||||
| Quote |
| Thanks from: | Stephen Wilde (13-06-2008) |
| | #19 |
I think I made this point earlier in another thread - science isn't about agreeing with people, its about agreeing with facts supported with evidence. If you want agreement with people, become a politician not a scientist. Last edited by splatz; 13-06-2008 at 11:54 AM. Reason: Typo |
| Quote |
| | #20 | |
"There's no such thing as surety in science -- 32,000 North American scientists signed a document saying humans don't create global warming whereas the Intergovernmental Panel on Climate Change only has 2500 scientists saying it does." Was this the 32,000 referred to ages ago on this forum, where I picked one at random and found out that the scientist was gainfully employed as a piano teacher at a very exclusive North American 'university'? Probably is the same list. So, if its alright with everyone I shall continue to trust the IPCC rather than a Liberace wannabee | |
| Quote |
| | #21 | |
You only need to see the type of language used in their assessment reports to see things dressed up to look sciencelike when in fact they are not. For example, in their 2007 policy document they attempt to replace words like Most, Likely and Very Likely with numbers. Here is the extract: snip "most" means greater than 50%, "likely" means at least a 66% likelihood, and "very likely" means at least a 90% likelihood. /snip They do this so they can then go on to state: snip There is a confidence level >90% that there will be more frequent warm spells, heat waves and heavy rainfall. There is a confidence level >66% that there will be an increase in droughts, tropical cyclones and extreme high tides. /snip The numbers look more "scientific" because it implies some form of calculation. They also quote wide ranging figures on their predictions: snip Sea levels will probably rise by 18 to 59 cm World temperatures could rise by between 1.1 and 6.4 °C /snip That is quite a margin of uncertainty (that's about 400% uncertainty for the temperature and about 300% uncertainty about sea level rises). If I quoted a 400% level of uncertainty into my projects plan estimates at work, I would be laughed at, then fired. So why do they do these things? Because they are asked to by the governments they are trying to convince to sign up and ratify their Assessment reports. At the moment, no government is going to stick their neck out if they don't feel the evidence is strong enough, so they lobby to dampen down the language. Governments may change this view if temperatures were significantly higher now. Now don't get me wrong, the IPCC does bring lots of important scientific work together, but their main task is to convince governments to sign up to the reports - and that process is politics not science. Just check out their About Us page and tell me if you are not sure on their remit.http://www.ipcc.ch/about/index.htm | |
| Quote |
| | #22 | |||||||||
The causal relationship betweeen the El Nino/LaNina cycles and other factors is not well understood. Quote:
And any cooling phase will not reverse the last 30 years of warming. And the rapidly rising acidity will do what to our marine life? Quote:
| Quote |
| | #23 | |
| Quote |
| Thanks from: | johntheexpat (13-06-2008) |
| | #24 |
The trouble with debate around CC is the lack of certainty. But there is 30+ years of coherent science that all points to a potential problem. One bit of decisive evidence, that is credible and stands up to peer review will sink it. That's all the cynics have to produce. It's not hard. bring it on! |
| Quote |
| | #25 | |
It is uncertain because there isn't one bit of decisive evidence that is credible and stands up to peer review to prove the case. That's all the activists need to produce. Its not hard. Bring it on. Oh - that's remarkably similar to what you said. Only the exact opposite . . . It would be too easy for me to say that the burden is on scientists to prove CC. However, science teaches that the burden of truth is not mutually exclusive to cynics or activists - it is for science to figure out one way or the other. For every scientist trying to prove something, there should be a scientist trying to disprove it but more importantly there should be an independent control group who doesn't know the source who verifies the results. At the moment we do not have the validation rigour on some of the material being published. But before anyone jumps in and says "well what about peer review!", peer review is very important but is not the same as double blind independent review. | |
| Quote |
| | #26 | |
Read my sixth article. The Title started off as a bit of journalistic licence but is seeming more and more apt. If solar influence can be re introduced as a significant player for the period 1975 to 1998 then AGW is mortally wounded or dead. | |
| Quote |
| | #27 | |
Whilst theoretically a greenhouse gas, CO2 is not a very effective one and, at just 4% of the atmosphere (with the anthropogenic contribution being even smaller), it is highly unlikely to have a significant effect on global weather patterns or temperatures. Secondly, climate change is natural and the world's climate has changed naturally since the dawn of time. The debate is whether this instance of change is prompted or augmented by anthropogenic CO2. I believe that, on balance, neither to be the case. Thirdly, I believe that the economic cost of trying to reduce global temperatures is so astronomic – and possibly pointless given the above – that we would do better spending on both adapting to change, whether that be for a warmer world or a cooler world, and on alternative technologies to reduce the long-term reliance on fossil fuel. Such technological advances will occur much faster if an economic depression is avoided. I would suggest that capping CO2 will have the effect of reducing our long-term ability to reduce consumption, thus ensuring a worse situation in 60 or 70 years time. Finally, I would point out that, in addition to the link I provided in my earlier post which concerned Ian Plimer’s claims that "There is no relationship between carbon dioxide produced by industry and climate change," (and I notice you made no comment about that!), I have since noted an interesting - and very recent - quote attributed to Patrick Michaels: “Even if CO2 emissions are returned to the level of horse-and-buggy days, an increase of 0.013 degree Celsius might be avoided over the next century.....That's if CO2 increases temperature, which many scientists doubt. So, why go down this path?” That sounds just like the position I hold! And yet you lambast me for being an extremist and holding a view which is contradictory to thousands who are skeptical of climate change. I don’t think so!! Oh, and just who is this Patrick Michaels? “Michaels is a research professor of environmental sciences at the University of Virginia and visiting scientist with the Marshall Institute in Washington, D.C. He is a past president of the American Association of State Climatologists and was program chair for the Committee on Applied Climatology of the American Meteorological Society. Michaels is a contributing author and reviewer of the United Nations Intergovernmental Panel on Climate Change. His writing has been published in the major scientific journals, including Climate Research, Climatic Change, Geophysical Research Letters, Journal of Climate, Nature, and Science, as well as in popular serials such as the Washington Post, Washington Times, Los Angeles Times, USA Today, Houston Chronicle, and Journal of Commerce. He was an author of the climate "paper of the year" awarded by the Association of American Geographers in 2004. He has appeared on ABC, NPR's "All Things Considered," PBS, Fox News Channel, CNN, MSNBC, CNBC, BBC and Voice of America. According to Nature magazine, Pat Michaels may be the most popular lecturer in the nation on the subject of global warming. Michaels holds A.B. and S.M. degrees in biological sciences and plant ecology from the University of Chicago, and he received a Ph.D. in ecological climatology from the University of Wisconsin at Madison in 1979.” And the link to the quote is here. | |
| Quote |
| | #28 |
After last summers ice melt off I can't believe people don't realize that using ice samples to determine past co2 levels is majorly flawed. In that if there has been warm trends in the past similar to last summer the ice that would have showed the co2 would have melted thus there would be periods of NO RECORDS. After all even antartica did not have ice on it at some point in the past. carbon dating isn't exactly precise either. So they revised that it actually took 10,000 years or so for the dinos to actually go extinct after the meteor. So all we can do is base it on today and in recorded history, Along with opening our eyes to see how much we actually changed earth in a negative manor. We NEED TO STOP PLAYING GOD by changing everything in our own flawed image. |
| Quote |
| | #29 | |||
| Quote |
| Post Reply |
E. & O.E.
LinkBack URL
About LinkBacks
