Some of you may have read or even contributed to the very
long thread about the Tefal QuickCup (and I was getting extremely anal about the maths of power requirements to heat up water!!), but I'd like to draw your attention to this
post I made.
Just to summarise:
Tefal market their QuickCup "kettle" (not really as it only heats water not boils it) as being able to save 65% of the energy of a "normal" 3KW kettle. This is more to being able to heat exactly the correct amount of water (rather than an overfill of the kettle) and to a lower temperature (+/- 85 degrees cf 100 degrees).
Well if you have one of those "newer" type kettles with a "disc" type heating element, I have found I can fill a cup of cold water, empty it into the empty cold kettle and have boiling water in 30 seconds. (One cup full did cover the whole bottom, so check yours first).
So, do yourself a favour, save energy and just put the exact amount of water you need into your kettle. According to Tefal that should reduce your normal kettle power consumption by 65%
