Originally Posted by Corey USA http://www.ipsnews.net/news.asp?idnews=38735
Take note to those who say there is not climate change of warming going on. this is biology and physics 101 in the works.
Consider this a "feedback loop" as well in that the more trees eaten by beetles the warmer it is going to get in the greenhouse effect the warmer it gets the more beetles will survive the winter where they were killed off before. It is also a demonstration on why we can not rely on earth carbon sinks as a means to put responsibility on others shoulders for undoing the damage we do.
I strongly encourage response to this by those who say there is not significant change happening.
This shows that we as humans need to shift the way we think and deal with things in that we plan long term (more than one generation) and implement action for long term benefits.
This is visible proof that we need to change and can not go on as business as usual.
We are the root of the problem . lets fix it. stop blaming it on the symptoms so to speak.
This rapid change is an example why we can not sit around and see do you even realize what this means when factoring in cutting of the rain forest? combined with acidification of the ocean which is killing the smallest organism which provide the bulk of our breathable air.
When taking it all together it shows we do not have that much time to make a difference and stalling is the same as murdering your own family only it is slow and painful. |
I have never said ti si not changing, we all know the climate is changing, what I have said is I don't believe Man is the main problem, .
The climate will change, that is fact, what can we do about it, no one knows.
So what would you want me to do about it? I will go and do it now.
Nothing I can do, nothing you can do, nothing anyone can do, just live the life you want to, we only got a limited time on this earth anyway, in another 40 years time I doubt very much if I will be alive, so what is the point in worrying what happens after I am gone?
Selfish maybe, but then so is most of the world.
