| Re: Philips CF lights at John Lewis
OK, here is the data. I seem to have got a bit confused with the bulb manufacturers names, but here is the full data set. It was written down in a note pad so there is no spreadsheet available...
Data is:
Manufacturer:
Rated power, peak power (at switch-on), power after 1 minute
Philips:
8W, 9W, 9W
Philips:
11W, 12W, 12W
Philips:
14W, 17W, 17W
Philips:
18W, 19W, 19W
Morrisons
5W, 9W, 7W
Status (I think this is an old Ikea bulb, but perhaps not)
7W, 9-11W, 9W.
Ikea (candle type)
5W, 13W, 7W
Note that the Philips bulbs came on instantly (as far as I could tell) and the others had a slight delay. The worst in terms of delay and initial brightness was the Ikea one - by far! Truly crappy, but it's used for a bed side light so it doesn't matter. I would estimate these have a 1 to 2 second delay! I have an Ikea ceiling light (I couldn't test) which also has a 1-2 second delay and are initially very dim.
The power meter (as mentioned, only an off the shelf unit) is made by Brennenstuhl, model PM230. It is *clearly* not designed for for monitoring transients in electrical power but it serves to give us a idea of power consumption at switch on and after a few minutes. All the bulbs were allowed to cool (after all even CF bulbs get warm) before consecutive readings were taken. Multiple readings were taken and bulbs measured in random orders - sort of.
So as far as I can tell, the idea that CF bulbs take large amounts of power at switch on is clearly wrong. Even if there is a huge power surge it would only last for a very, very short time and so not use much energy at all.
As for these bulbs being dimmer than others, I cannot say I have noticed - I can only suggest, if you use a 100W bulb, buy the equivalent of a 120W CF bulb. I must be living in a cave compared to some of you guys (!) as I use only an 18W CF bulb for a 4m x 5m room and it seems fine to me.
I have to say that it really annoys me that the likes of Ikea and B&Q, for that matter, sell such poor bulbs and at such inflated prices. It give the bulbs a bad name. So there we go - remember John Lewis sell these rather good bulbs for just 49p.
Rob
PS I don't work for Philips or John Lewis!
