3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
Today's price checkPowered by
Logitech HARMONY ONE
Logitech HARMONY 1100
Mitsubishi Electric XD/SD206U Remote Control
Venom Wii Remote Silicon Glove Twin
Mitsubishi Electric XD/SD206U Remote ...
Marantz RC-101
Sonos CR200
Bose WAVE® music system large remote ...
Marantz RC-3001
Sonos CR100
Bose WAVE® music system remote control
 More...Prices updated November 8th at 5:30pm and include delivery.
Logitech Harmony 1000 and 1000 Advanced- Is there a difference? gilesparnell Remote Controls 3 12-01-2008 10:05 PM
Harmony 1000 v 1000 advanced braehead Remote Controls 3 08-09-2007 6:05 PM
HArmony 895/1000 skipping issues hornydragon Remote Controls 13 06-07-2007 8:28 PM
Old 17-09-2008, 3:46 PM   #1 (permalink)
Thanks: Gave 82, Got 22
Please Help! 2 Issues With My New Harmony 1000
Loving this remote so far except for 2 things:
1) When using Virgin Media V+ box to watch TV the colour buttons are greyed out and can't be used and also there is no V+ button to watch recorded programs.
2) In Windows Media Centre everything works apart from the back button which seems to be mixed up with the OK button, means once I start playing an album I can't go back!
Any Ideas? Cheers guys.
Macron is offline   Reply With Quote
Old 17-09-2008, 3:53 PM   #2 (permalink)
Thanks: Gave 42, Got 544
Re: Please Help! 2 Issues With My New Harmony 1000
Looks like you have some "learning" and customising to do of missing or mis-located commands.
Better check with Logi support whether the receiver allows for colour buttons.
My opinions expressed here do not represent those of AV Forums or associated websites - Tosh 42X-3030DB, Thomson 607120Q Sky+ HD, Technomate 6800 HD, Passion+ HD, Technics SA-DX940, Bush BluRay, Tosh HD-EP30 HD-DVD, P-B EHR-2080 HDD/DVD Rec, Tosh SD-23VB DVD/VHS, Thomson DTI2300, Harmony 525-One-900-1100
logiciel is offline   Reply With Quote
Old 17-09-2008, 4:23 PM   #3 (permalink)
I've tried everything, been trying for a couple of hours now, tried deleting the device and adding different variations, tried manually teaching it, its just not having any of it
Old 17-09-2008, 4:34 PM   #4 (permalink)
OK found a fix for V+ (Does the Harmony 1000 work with virgin V+box) but Media Centre still won't play.
Old 17-09-2008, 7:32 PM   #5 (permalink)
Logi support are there to be consulted!
Old 17-09-2008, 8:43 PM   #6 (permalink)
I figured it out. Partly my fault but tbh the software can be a bit silly at times. Basically I had the back button correctly assigned but by default in the listen to music activity the back button is channel up. Makes no sense at all why you would want that but anyway, changed it so that back meant back in music and video and now its perfect.
I'm slowly getting the hang of this thing.
1000, harmony, issues
