Logitech Harmony 785 - a few newbie questions
Old 29-04-2008, 9:29 PM   #1
Andrathion's Avatar
6,692, Level: 19
Points: 6,692, Level: 19 Points: 6,692, Level: 19 Points: 6,692, Level: 19
Thanks: Gave 12, Got 3
I'm sorry if this is pretty basic - just got the Harmony 785 today, and couldn't find an answer to this:
1. How do I operate a single device (say, a TV) without switching activities on or off?
My main reason for asking is that I'd like to be able to switch a device (say, a TV) on or off without disrupting the current activity (say, listening to a CD). I thought the simple answer to this was to hit the "Devices" button on the remote and take it from there, but I'm not sure what to do next. If I'm listening to a CD, hit "Devices" and then "TV", nothing happens. If I press the on/off button, the amp/dvd-player shuts down.
2. How do I set up the same activities, but using different devices? I'd like two "Watch DVD" activities, for example, since I have two set-ups, each with its own TV, amp and DVD player.
Again, my apologies if this is very basic, but, well, the lack of a manual seems to have me stumped...
Old 30-04-2008, 7:56 AM   #2
4,326, Level: 15
Points: 4,326, Level: 15 Points: 4,326, Level: 15 Points: 4,326, Level: 15
Thanks: Gave 20, Got 46
Re: Logitech Harmony 785 - a few newbie questions
Hi, welcome to the wonderful world of Harmony Remotes.
All models work basically the same and they are IMHO great BUT you do need to accept that ACTIVITIES are the Harmony Way!
A key thing to remember is that ACTIVITIES remember STATE i.e. what Inputs & Power commands were last sent and if you upset these then you get out of sync. Not a problem per se but still best avoided. Also this can happen when a device does not receive a command as somebody walked between them at the crucial point!!
Now, you CAN operate things in Device Mode BUT these are normally just for set up or occasional use as they can (& will) upset the STATE.
Most users should not need to leave activities in normal use as they can make any commands not available on the hard keys available on the display keys WITHIN the activity. (You can also remap the Hard keys if you wish).
So to do what you want in ACTIVITIES it would be best to have another activity e.g. Watch&Listen in which you use the TV & CD. Then switching between activities will remember state!
For your 2nd question, again, just set up another activity to use the different gear, however, you will need to look at your POWER options carefully, to decide what happens to non used devices when you are in an Activity. Look in ACTIVITIES>SETTINGS>Change OPTIONS
REMEMBER the POWER button is an JUST AN OFF button and POWER ON is taken care of through the ACTIVITY.
Have a play around and come back and ask more, it is always difficult to know where you're at so I am in danger of writing a thesis here
Alan
Andrathion (14-05-2008)
Old 09-05-2008, 9:06 AM   #3
8,900, Level: 22
Points: 8,900, Level: 22 Points: 8,900, Level: 22 Points: 8,900, Level: 22
Thanks: Gave 71, Got 134
another question...
with regards to the 'One-touch activity buttons' if i set up a play dvd botton as in : turn on tv >switch to hdmi input >turn on dvd player> open dvd tray.
what would happen if the tv is already turned on? would the activity switch the tv off, or does it somehow already know the tv is on?
also is this compatable with windows vista?
Old 09-05-2008, 9:43 AM   #4
4,326, Level: 15
Originally Posted by snellfish View Post
another question...
In the Vista compatable software in Devices tab, set the TV Power Option to 'I want to turn this off when not in use' (or something like that) which means it will stay on when switching to anything that uses it.
If you find it is switching off, go back to Devices>CustomiseButtons>Additional Buttons and check to see if your TV has Discrete Power On & Off (your OEM RC may just have a power toggle) if they are there reset the Power Options to use the Discrete ones.
Another point to Remember: in the Activities tab, check in Change Options, as it has some other self explanatory power settings.
snellfish (09-05-2008)
Old 09-05-2008, 12:00 PM   #5
70,061, Level: 64
Points: 70,061, Level: 64 Points: 70,061, Level: 64 Points: 70,061, Level: 64
Activity: 99.8%
Activity: 99.8% Activity: 99.8% Activity: 99.8%
Thanks: Gave 1,255, Got 3,016
Award-Showcase
If the TV is already turned on at the set, or by using another remote, and if the power switch is an on/off then yes it would.
Harmonys are clever, but only clever enough to remember what they have done, not what something else has done.
Yes the software works in all Windows.
Do as saintalan says and you can't go wrong!
Old 14-05-2008, 10:28 PM   #6
Andrathion's Avatar
6,692, Level: 19
Alan
Hi Alan! Sorry for the very late response, but I just wanted to say thanks!
Unfortunately, I am at the moment devising devious ways of making my brand new Harmony 785 suffer in the most excruciating ways imaginable. It does nothing the way i want it to...
I clearly have no understanding - let alone appreciation - whatsoever of the wonders of Activities and am thinking mostly of vinegar and ammonia concoctions to subdue this dreadful little beast.
Ahum. Sorry. I'll admit to being all flustered & hating it! But I do appreciate everyone's posts, and it was high time I mentioned that!
Cheers, guys - and I'll get back to this once I've settled down and can be coherent again...
Old 14-05-2008, 10:44 PM   #7
70,061, Level: 64
Activity: 99.8%
Award-Showcase
Originally Posted by Andrathion View Post
....the lack of a manual seems to have me stumped....
It's a bit late for this - there is a manual, in the software, weirdly, at Tip Centre> More Help.
The basics - do everything in Activities, for each of them select its type, specify which Devices it has to include and which of them does the basic things like setting channels or controlling volume, when they're all set up forget Devices, throw away the original remotes, only press Off when you've finished a viewing session.
Old 17-05-2008, 10:30 AM   #8
TheCat's Avatar
3,564, Level: 14
Points: 3,564, Level: 14 Points: 3,564, Level: 14 Points: 3,564, Level: 14
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 12, Got 0
I bought a 785 recently and have a few queries.
It is impossible to do some things just using an activity so you need to go to devices to finish off.
For instance, I have a HDD DVD player so to watch a recorded program the HDD needs to boot up and this takes a minute or so. To look at your list of programs, you need to then hit another button so go to devices.
Once done, this means that the volume buttons are trying to change the HDD whereas I want them to work the amp at all times.
Is there a way to set the volume buttons to only work one device?
Old 17-05-2008, 7:16 PM   #9
70,061, Level: 64
Activity: 99.8%
Award-Showcase
I've never found anything, no matter how complicated, that can't be done in Activities.
This one isn't complicated - a Watch DVD Activity that includes TV and amplifier and DVD player will give control of the volume to the amplifier and will provide buttons for all the functions of the DVD, so that there will never be any need to go from an Activity into Devices.
Old 19-05-2008, 12:44 PM   #10
TheCat's Avatar
3,564, Level: 14
Activity: 1.5%
I think the answer is to add more commands so that you don't need to leave the activity.
I've been doing that this lunchtime and hopefully that will solve my problems.
Old 19-05-2008, 4:41 PM   #11
70,061, Level: 64
Activity: 99.8%
Award-Showcase
That's right - it's the way all Harmonys are meant to work.
For any Activity you're presented with the selection of commands that it thinks you need from each device,
but you can add, remove, or change them around, any way you like.
Old 22-05-2008, 1:10 PM   #12
Andrathion's Avatar
6,692, Level: 19
Alright, I'm back & calm enough to ask a question or two. Oh, and my 785 is still intact, surprisingly .
I've been fiddling for days now, but here's the thing: I can't get my TV to go to the correct input in my "Watch DVD" and "Play Game" activities.
I've listed my full setup below, but here are the basics. I have a Hitachi 42PD6600 TV. Unfortunately, it doesn't have dedicated input buttons on its remote: it has a single toggle button which you need to press repeatedly when switching from one input to the next.
To watch a DVD or play a game (PS3), I need both activities to switch the input from "TV" (the default when the TV is switched on) all the way up to "EXT 6" (my hdmi input from my Denon amp).
I can't get either activity to do that. I've obviously specified the correct input using the Harmony's software (which lists all the inputs correctly), but in practice, the TV will switch up to "EXT 5" and then stop.
Any ideas? I must admit I'm stumped. I've tinkered with everything I could think of, including the delay settings for the TV, but nothing seems to work.
_________________
Setup: Denon 3806 amp, Denon 3910 DVD player, Hitachi 42PD6600 TV, PS3, Digital cable box (a UPC "Mediabox").
Connections: 3910 to 3806: Denon Link & HDMI; 3806 to TV: HDMI; Cable box to TV: SCART
Old 22-05-2008, 2:56 PM   #13
4,326, Level: 15
... I have a Hitachi 42PD6600 TV. Unfortunately, it doesn't have dedicated input buttons on its remote: it has a single toggle button which you need to press repeatedly when switching from one input to the next....
Welcome Back
The important thing is NOT what your Hitachi Remote has BUT what the Harmony (Database) has!
I used to have a PD5200 and it had most inputs.
On your Harmony Remote go in to DEVICE mode and scroll through the Display and see what DISCRETE INPUTS it has and try them on your TV to see what works. If it has the ones you need then in the Software use Inputs Option 2.
Cheers, just checked your Device looks like it has 22 input options!!
Andrathion (22-05-2008)
Old 22-05-2008, 5:25 PM   #14
32,091, Level: 43
Points: 32,091, Level: 43 Points: 32,091, Level: 43 Points: 32,091, Level: 43
Thanks: Gave 116, Got 658
Yes, even when your remote only has one button it has the separate commands for inputs as if your tv remote had lots more buttons on it.
Old 22-05-2008, 6:24 PM   #15
Andrathion's Avatar
6,692, Level: 19
Okay - thanks guys! I didn't know that!
I'm off to try it in a moment or so & will let you know...
Old 22-05-2008, 6:38 PM   #16
Andrathion's Avatar
6,692, Level: 19
Okay, I tried it. You're right: there are about 22 input options (not sure about one called "Lang", though).
Unfortunately, none of them seem to do anything at all. The only command that works is the "InputNxt" one, which is the toggly one.
I'm probably just missing something obvious here, but I'm darned if I know what it is.
P.S. For what it's worth, the Harmony software has automatically stored some commands which I know aren't applicable for this particular TV. For example, there's a "swivel" option. Some Hitachi's have that; this one doesn't. So perhaps this TV doesn't have dedicated input commands after all, in spite of the fact that the software seems to think so?
Old 22-05-2008, 10:27 PM   #17
Bachstrad's Avatar
10,748, Level: 24
Points: 10,748, Level: 24 Points: 10,748, Level: 24 Points: 10,748, Level: 24
Thanks: Gave 1,076, Got 269
Sounds like you need to put in a call to those 'ever so helpful' people at Logitech Customer Service!
ATB
Max
Old 23-05-2008, 12:17 PM   #18
70,061, Level: 64
Activity: 99.8%
Award-Showcase
I need both activities to switch the input from "TV" (the default when the TV is switched on) all the way up to "EXT 6".
If it consistently goes only as far as 5 then all you need to do is add an "input next" as "Addtitional command when activity starts".
Andrathion (23-05-2008)
Old 23-05-2008, 5:31 PM   #19
Andrathion's Avatar
6,692, Level: 19
Err, I think this is where I reveal the vast scope of my intellect.
I have no idea of how to do that
Old 23-05-2008, 5:47 PM   #20
4,326, Level: 15
Activity Tab>Review Settings>Yes, but...> followed by a few Nexts and Saves etc then you will come to the screen where it tells you what devices are used and what start up commands have been set by the Activity.
You can add any start up commands of your own there.
For future ref, you can also add EXIT commands
Old 23-05-2008, 5:49 PM   #21
32,091, Level: 43
Settings
Review Settings for this activity
Yes but I want to add more control
Save
Add
TV Input next
Old 23-05-2008, 7:16 PM   #22
Andrathion's Avatar
6,692, Level: 19
Okay, just added not one, but three Input Next commands - and now it seems to work! Fingers crossed, but looking good...
There's clearly still some miscommunication going on (the TV should be on "EXT OUTERSPACE" or thereabouts by now), but who cares?
Once again, thanks!
Old 23-05-2008, 11:21 PM   #23
70,061, Level: 64
Activity: 99.8%
Award-Showcase
I have no idea of how to do that.
....just added not one, but three Input Next commands
You do now
One should have been enough but presumably once it gets to 6 it can't go any further and doesn't start again at 1.
Old 24-05-2008, 11:16 AM   #24
32,091, Level: 43
Once again, thanks!
That suggests actually that your timing is too fast for the device to activate a command properly. Although you have it working, you might... one day... when you are feeling a bit more knowledgeable about the remote.. wish to get the timing slower, so that the TV can accept the commands as they are sent to it. You can then probably remove all of the new commands from the startup.
Old 25-05-2008, 7:48 PM   #25
Andrathion's Avatar
6,692, Level: 19
Yes, I realise that. In fact, I'd already been tinkering with the delay settings for a while before I realised - thanks to you guys - that I could enter additional commands. Tinkering to no avail, though - even setting the delay to beyond the 3 second max (3000 ms) suggested by the software didn't help.
You're right - I'll get back to these settings. If only because I now get the correct input when starting my "Watch DVD" activity from scratch - when, in other words, everything's turned off to begin with - but not when switching from "Watch TV" to "Watch DVD" (when I do that, it moves further on to the "PC Input").
For the moment, though, I'm happy enough. I'll just sit here and tinker a bit more. And then, no doubt, I'll come back & start grumbling all over
Cheers,
Alex
Old 01-06-2008, 1:08 PM   #26
mrapriliafalco1's Avatar
4,709, Level: 16
Points: 4,709, Level: 16 Points: 4,709, Level: 16 Points: 4,709, Level: 16
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 1, Got 22
just bought a CYRUSLINK Linkdock for a IPOD how would you list it under devices any ideas what category to place it under
Powered by
 Latest popular product prices
Venom Wii Remote Silicon Glove Twin
1 price
 £7.98 Click to show/hide the offers
Startech Adapter Kit For 2.5" Hd...
1 price
 £10.78 Click to show/hide the offers
John Lewis 2-Way Remote Control
1 price
 £13.00 Click to show/hide the offers
Apple Remote
1 price
 £19.50 Click to show/hide the offers
Lindy 3 Port Hdmi Switch With Re...
1 price
 £20.38 Click to show/hide the offers
SKY TELEVISION SKY150
1 price
 £29.09 Click to show/hide the offers
Microsoft Xbox 360 Media Remote ...
1 price
 £22.95 Click to show/hide the offers
SONY Blu-ray Remote Control - fo...
1 price
 £19.99 Click to show/hide the offers
 Updated February 11th at 1:30pm. Prices include delivery.
