AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 01-04-2008, 3:53 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Harmony One problems
I've just started setting up my Harmony One but i'm having big problems
I created account/set up my devices and then set up my activities - no problem
When i finally came to 'updating the remote' all seemed to be going fine but on the next screen where it prompts you to disconnect usb and try the remote nothing works on the remote
All i get is a slideshow of Logitech images, if i press the activities button as recommended all that happens is the images cycle quicker.
At no point does any touch screen 'buttons'/icons appear
I've tried removing the battery and trying again
I've rang customer support and put the remote into 'safe mode' and restarted NO HELP
I'm awaiting an email from technical support but this could take 2 days
Any ideas chaps or do i have a duff one
sogden is offline
Old 01-04-2008, 4:03 PM   #2 (permalink)
barongreenback's Avatar
Thanks: Gave 117, Got 64
Re: Harmony One problems
Have you tried touching the pictures? What happens then. What specifically are the pictures on the screen?
Just take it as read that I spend too much on gadgets and gizmos
barongreenback is offline
Old 01-04-2008, 4:06 PM   #3 (permalink)
Kryptix's Avatar
Thanks: Gave 57, Got 123
As above really... What do you see? Are the activities on the screen correct? What happens when you touch the screen? Are you sure you've added the correct devices? It took me 3 attempts to add the right Sky HD box.
Samsung PS42Q97HDX | Harmony One | Sky HD | PS3 (60gb) | Onkyo TX-SR605 | Tannoy Revolution R3 (7.1) | Tannoy R-SUB 15 | N95 8GB
Please comment: HD 7.1 Bedroom Setup & HD 7.1 THX Living Room Setup
Kryptix is offline
Old 01-04-2008, 5:35 PM   #4 (permalink)
The pictures on screen are the Logitech symbol and four pictures of the remote
I believe this is just the inbuilt screensaver
No activities show
Touching the screen causes a beep and the next picture to appear
I've followed the software prompts to the letter about four times and none of my activities have appeared on the remote
sogden is offline
Old 01-04-2008, 6:28 PM   #5 (permalink)
fredsie's Avatar
Thanks: Gave 71, Got 78
When you spoke to Logitech did they get you to download the PC software? If not, I would do this now and reinstall. My first experience was not good either - turned out the software on the CD in the box was incompatible with the firmware on the remote!
fredsie is online now
Old 01-04-2008, 9:10 PM   #6 (permalink)
Thanks: Gave 29, Got 177
Between pressing Update Remote and getting the message to disconnect and test did you get a scale probably starting at 3% then probably pausing briefly at 90% before completing at 100%?
hhatkin is offline
Old 02-04-2008, 4:19 PM   #7 (permalink)
Exactly
sogden is offline
Old 02-04-2008, 4:21 PM   #8 (permalink)
Tried reinstalling from there website and doesn't seem to make any diff
sogden is offline
Old 02-04-2008, 5:31 PM   #9 (permalink)
fredsie's Avatar
Ah well, worth a try (although it is a 53mb download!). That fixed mine. (Well, that and the firmware download).
As you've done both of these, and your upload runs to 100% I can't think of anything else to suggest. Looks like it's duff, I'm afraid.
Old 02-04-2008, 6:33 PM   #10 (permalink)
Exactly
Have you now gone through the "upload remote" procedure again using the latest software version 7:4:3?
If you ever have the patience to go through it yet once more:
all the time when the remote is connected by USB does the screen display "USB connected"?
at the 90% stage does this briefly change and then return until 100% and you disconnect the USB?
does the slideshow appear immediately after this?
do words appear on the screen above one or both of the two virtual buttons that appear below the bottom of the screen (like the arrows at the sides)?
hhatkin is offline
Old 03-04-2008, 4:28 PM   #11 (permalink)
Tried and no success
Yes the screen does show usb connected as you described
After spending 30mins speaking to Logitech technical support in the USA they said i've probably got a duff one
Sending it back for another one, hopefully better luck next time
sogden is offline
Old 03-04-2008, 7:34 PM   #12 (permalink)
Yes, I had two, you should be OK with your second one.
hhatkin is offline
Old 21-05-2008, 7:58 AM   #13 (permalink)
Having just bought the harmony one it has become imeadiately infuriating. I own a mac mini and when i run the remote update software it asks me to connect the remote to the USB port. I do this, and click continue only to be asked the same question again...and again and again.
Anyone got any ideas?
a271249 is offline
Old 21-05-2008, 8:06 AM   #14 (permalink)
fredsie's Avatar
I'm assuming it's fully charged!
Sounds like a USB issue. Not that sure how Macs work but with Windows-based machines when you plug in a new USB device you get some reaction from the operating system, "new hardware found" or somesuch. Does this happen for you, when the remote update software is not running? If not, your machine doesn't seem to be reacting to the remote as a USB device. Is it OK with other USB devices?
harmony, problems
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Harmony 525 - problems already!!!! AndyB1973 Remote Controls 16 21-01-2008 8:11 PM
Harmony 525 Problems 24inchgamer Remote Controls 3 19-03-2007 4:03 PM
Problems with Harmony 525 don-tucker Remote Controls 6 24-12-2005 7:57 PM
More problems with harmony 655 adriandg Remote Controls 0 06-12-2005 10:47 PM
harmony 655 problems leew914 Remote Controls 5 23-10-2005 12:57 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
