AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 01-04-2008, 12:38 PM   #1 (permalink)
Ultima's Avatar
Thanks: Gave 401, Got 373
Copying Harmony device/activities settings to 2nd Remote
I have purchased a second Harmony Remote. Is there anyway that I can copy the settings from my original remote to my new remote?? What is the easiest way to achieve the same device/activities settings on the new remote without having to go through the setup routine in full.
I will be keeping both remotes.
Martin
Martin
AVF PS3 Fifa 2009 League - Stockport County
Ultima is offline
Old 01-04-2008, 1:20 PM   #2 (permalink)
fredsie's Avatar
Thanks: Gave 71, Got 78
Re: Copying Harmony device/activities settings to 2nd Remote
Copying the setup to a new remote is one of the options in the online programming site.
fredsie is offline
Old 01-04-2008, 1:28 PM   #3 (permalink)
Ultima's Avatar
I've looked but must have missed that....I can copy my settings to a new remote but it doesn't keep my original remote details.
I'll have another look.
Regards
Martin
Martin
Ultima is offline
Old 01-04-2008, 3:14 PM   #4 (permalink)
fredsie's Avatar
Well I must confess I've not had occasion to try it myself. At the bottom right of the "Remote settings" tab there's a button marked "Have a new harmony remote? replace Remote". I'd always assumed that I could use this to copy my settings to a new remote. Then if there were further setting changes to be made, I could use it again to update the first one, etc.
fredsie is offline
Old 01-04-2008, 3:18 PM   #5 (permalink)
Ultima's Avatar
Yes that's what you have to do...but I wondered if there was anyway that I could just setup an new account called "martins 1000" for example and copy my settings from my "martins 885" account. Then I could mess about with each account independently of each other. Doesn't look like it though.
Martin
Martin
Ultima is offline
Old 01-04-2008, 3:34 PM   #6 (permalink)
fredsie's Avatar
Yeah, I guess if you want to keep the two setups separate (and different) then you'll have to set up a new account from scratch.
fredsie is offline
2nd, copying, device or activities, harmony, remote, settings
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Harmony 555 activities jwindley Remote Controls 19 26-01-2008 7:58 AM
Harmony Activities - Device Volume Control/Pass Through Question matturin Remote Controls 2 07-02-2007 8:17 AM
Harmony 525 Activities Bobman Remote Controls 15 04-02-2007 8:34 PM
Harmony 525 Activities Help dfloat Remote Controls 4 18-09-2006 10:20 AM
Harmony 885: Change the current "Device" after activities start jih Remote Controls 3 01-03-2006 1:57 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
