AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 31-03-2008, 7:10 AM   #1 (permalink)
fredsie's Avatar
Thanks: Gave 71, Got 78
Setting the time on 885
Yesterday evening I noticed that the time on my Harmony 885 (which is set to am/pm mode) was an hour out following the start of BST. Easy I thought, you can change the time using settings on the remote itself. Wrong! I can set the year, month, day and minute, but when it comes to setting the hour, I only have 1 to 12 to choose from, and the remote assumes this is AM. You can't reset the time after midday it seems. Had to wait until this morning to put it right!
fredsie is online now
Old 31-03-2008, 9:11 PM   #2 (permalink)
D-an-W's Avatar
Thanks: Gave 90, Got 44
Re: Setting the time on 885
Same problem here matey, if you update the remote via the software it also sets the time.
D-an-W is offline
Old 31-03-2008, 9:39 PM   #3 (permalink)
fredsie's Avatar
Yeah, thanks - seems a bit of a sledgehammer to crack a walnut though. I haven't tried it but I expect if you set it to 24 hour mode you get a full set of hours. Just an oversight on Logitech's part I guess.
885, setting, time
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Tom Tom One V2 Time setting DGP999 Satellite Navigation (Sat Nav) 2 03-04-2007 1:45 PM
Asus A8N-VM CSM Setting Up First Time meansizzler Computer Systems 10 06-01-2006 9:15 PM
Setting up a G 70 for the very first time artoj CRT Projectors 0 02-01-2006 10:45 PM
Setting time on 32PF9830 juljuljul66 LCD Televisions 0 08-12-2005 2:06 AM
Setting up an amp for first time - help needed! Tejstar Integrated AV Amplifiers and Receivers 15 01-12-2004 2:52 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
