AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 29-03-2008, 1:42 PM   #1 (permalink)
Dave964's Avatar
Thanks: Gave 0, Got 78
RFX9600 and wireless extender
Thought I'd start a new thread rather than add this to the TSU9600 one.
My wireless bridge turned up (I ordered this : http://www.amazon.co.uk/exec/obidos/ASIN/B00030I18A - although in fact, a gaming adapter turned up although that's basically the same thing).
I initially was not happy - it was sent from Germany and hence has a Euro power supply. However, the suppliers responded very quickly to my complaint and - if they've stuck to their word - a UK power supply should have been delivered to my work last week.
Anyway - it works fine. Initially it didn't - for some reason, the extender has to be powered on after the bridge - otherwise the extender gets an IP address but it doesn't seem to get a "real" connection and the remote can't see it. But if you power up in the correct order, all is fine. So my extender is now talking to my router upstairs wirelessly - well worth considering if you have the same problem as me, and only about £40 in cost.
Dave
SB+, Chord CPM 2600, Pioneer PDP-428XD, Sky HD, PS3, Sony STR-DA5200ES, MA GS10s, MA GSLCR, MA RSFXs, BK XLS300, Pronto TSU9600
Dave964 is offline
Old 29-03-2008, 11:55 PM   #2 (permalink)
andicapped's Avatar
Thanks: Gave 14, Got 26
Re: RFX9600 and wireless extender
good to know that works. i was having the same problem as you. although i havent yet got the rfx9600 i was trying to figure out how to wire it to my router upstairs.
i've since put i wire wire in place but i'm hopefully moving house this year and wont be running cables all over the place so you've come up with yet another great idea.
PSN : andicapped
andicapped is offline
extender, rfx9600, wireless
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Devolo dLAN Wireless Extender -54 Mbps over Wireless LAN oldman100 Wii 4 18-03-2008 4:53 PM
Devolo dLAN Wireless Extender - 54 Mbps over Wireless LAN oldman100 PS3 PlayStation Network 1 18-03-2008 12:28 PM
Wireless extender to 360 The Klinker Xbox 360 0 18-06-2007 11:28 PM
MCE PC wireless extender options? Mocha Dragon Networking 1 03-03-2006 9:50 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
