AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 28-03-2008, 12:13 PM   #1 (permalink)
Thanks: Gave 7, Got 0
Best remote control? Harmony or Xantech?
I'm after a Universal Remote that will control:
Sony STRDG910B
Apple TV 40Gg
Austar (PayTV)
PS3 (if converted to IR)
Sony KDL40XBR3100 LCD TV
I've had suggested for the remote: Logitech Harmony 785, or Xantech URC 2.
I want one that when I've set it up I can copy it's setup to 2 others. Any comments or suggestions?
I also need an IR Extender Control kit, so I can lock these items in a cupboard and control all of them from outside the cupboard.
gdaymate2 is offline
Old 31-03-2008, 6:20 PM   #2 (permalink)
fredsie's Avatar
Thanks: Gave 71, Got 78
Re: Best remote control? Harmony or Xantech?
Sony STRDG910B
Apple TV 40Gg
Austar (PayTV)
Well I don't know about the Xantech but the Harmonys (Harmonies?) should operate anything that is infra-red controlled, since they can learn the codes from your existing remotes if the device is not listed (but thousands are). As to copying the setup, the online programming approach works by storing your configuration and key commands on the harmony website and then downloading the data to your remote by USB, so your need to programme multiple remotes (even different Harmony types) shouldn't be a problem.
fredsie is offline
gdaymate2 (01-04-2008)
Old 03-04-2008, 2:17 AM   #3 (permalink)
Kryptix's Avatar
Thanks: Gave 57, Got 123
http://www.IR2BT.com
Best device out for the PS3.
Samsung PS42Q97HDX | Harmony One | Sky HD | PS3 (60gb) | Onkyo TX-SR605 | Tannoy Revolution R3 (7.1) | Tannoy R-SUB 15 | N95 8GB
Please comment: HD 7.1 Bedroom Setup & HD 7.1 THX Living Room Setup
Kryptix is offline
Old 14-04-2008, 10:43 AM   #4 (permalink)
I bought the 785 and am testing it, but can't understand why the cradle hasn't been designed to fix to a wall. You have to lay it horizontal, which takes up space and means there's a danger you'll knock it off easily. It seems a bad design.
Old 14-04-2008, 6:47 PM   #5 (permalink)
fredsie's Avatar
Yes the charging system has come in for some flak - somtimes the contact is not well made and the remote fails to charge (people have been putting heavy things on top to ensure the connection!) I think this has improved in current models, and mine so far seems OK.
fredsie is offline
control, harmony, remote, xantech
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Remote control of TV backlight via Harmony remote daveevans87 Home Automation, Lighting, Security, Heating and Cooling 12 18-01-2008 8:57 AM
FS: Harmony 885 Remote Control Steve-L Archive : Completed Business and Expired Threads 6 17-11-2006 3:21 PM
Can I use a Harmony remote to control my PC booms Remote Controls 9 15-06-2006 8:03 AM
FS: Harmony 655 Remote Control Parmenion Archive : Completed Business and Expired Threads 7 03-03-2005 6:26 PM
Harmony SST-768 Remote Control scgf Archive : Completed Business and Expired Threads 15 11-12-2004 4:16 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
