28-03-2008, 2:44 AM
#1 (permalink)
Thanks: Gave 9, Got 61
Proper Solution to replacing the PS3 remote NOW AVAILABLE
[IMG]removed;moderator[/IMG]
A guy in the States has just launched (today) a device that converts ir - bluetooth.
A little black box (about the size of a packet of fags) receives the ir commands from a universal / learning remote, then converts it to bluetooth to be sent wirelessly to your PS3.
The guy (Bruce Mitchell) has been working on this for months trying to get everything 'just right'. He's even managed to get it to power on/off and get the PS button working.
I've been following the progress of this since it started and have just placed my order.
Webshop
irbt forum
First 200 sold out in 12 hours on 28/03
Another 300 available from 5pm Sun 06/04
Reason: Image removed in accordance with rule 9.
28-03-2008, 3:13 AM
#2 (permalink)
Thanks: Gave 57, Got 123
Re: Proper Solution to replacing the PS3 remote NOW AVAILABLE
I already posted this in the PS3 section, but it's good that it's here too.
The order form is: http://www.ir2bt.com/cart
Samsung PS42Q97HDX | Harmony One | Sky HD | PS3 (60gb) | Onkyo TX-SR605 | Tannoy Revolution R3 (7.1) | Tannoy R-SUB 15 | N95 8GB
Please comment: HD 7.1 Bedroom Setup & HD 7.1 THX Living Room Setup
28-03-2008, 9:04 AM
#3 (permalink)
Thanks: Gave 2, Got 2
I've been following it for a while as well, and got the "we're taking orders" note this morning. I was order number 89, when I placed mine about an hour ago. So he's almost sold half his initial stock.
28-03-2008, 11:11 AM
#4 (permalink)
Thanks: Gave 0, Got 2
http://www.schmartz.com/main.sc
which is the better of these products? Has anybody followed the development of both products?
Arcam DV29, Arcam AV8, Arcam P7, Arcam P1's x3, ATC SCM35's, ATC C3, M&K SS-150's, M&K CS-29's, Isotek Substation, Apair of diy subwoofers, Crown K2 amplifier, Velodyne SMS-1, DVDO VP50 with sdi, Sky+ SDi, Optoma H79, Panasonic 42PH10. The rest still in progress...
28-03-2008, 11:21 AM
#5 (permalink)
Originally Posted by flamingoboo
I'd only heard of this one a week or so ago, but I don't like it's power on method, having to pair the PS3 with a PSP is an extra step, but it's the wire with a sticker over power button which just looks like an ugly hack to me really.
I was initially looking at the IR4PS3 (reviewed here http://www.remotecentral.com/article..._ir_remote.htm) which is more of a mod of the current PS3 BR remote to accept IR input, until I found the ir2bt device - I just think it's the neatest and better solution right now. No doubt even better ones will appear in time, but for me this is the best thing out there at the moment
29-03-2008, 2:01 AM
#6 (permalink)
They've sold out already
Glad I got my order in when I did. I was order no 4
They should be more stock in one week's time. This product is most certainly the best of the solutions available. All of the original bluetooth commands have even been included on the Harmony database already.
29-03-2008, 11:05 AM
#7 (permalink)
Thanks: Gave 41, Got 37
Luckily i got in on the first batch as well (#81), just gone out and bought a ps3 to go with it!
What is it in under on the harmony database?
30-03-2008, 1:31 AM
#8 (permalink)
Device: Games Console (with DVD)
Make: IR2BT
Model: IR2BT
30-03-2008, 10:49 AM
#9 (permalink)
Thanks: Gave 60, Got 97
Damn, wish id seen this a few days back.
So how much is this all in shipped to the uk?
I take it you just pop this unit anywhere with a line of site to your remote and it does what it says on the tin. Its a shame it cant go on top of the PS3 really.
Im going to site the site as my homepage and see if I can nab one of the next batch.
Also I take it this device needs to be powered somehow, is it a multivoltage device etc? And does it come with the power cord or not? What do we need to do in the UK to power this?
If anyone wants to sell theres, lmk.
30-03-2008, 12:22 PM
#10 (permalink)
Thanks: Gave 4, Got 11
Cost to the UK is $55 + $20 shipping.
It's an IR receiver so has to be in line of sight with your universal remote though I suspect that most of us will be using an IR extender so placement won't be a problem. Personally I'd have thought that having on top of the PS3 would be the worst place to have it: mine will be tucked away out of sight.
It is powered by two AA batteries or via a USB cable i.e. 5v. It's fairly easy and cheap to pick up a mains adaptor to turn a cable into a power supply.
All I have to do now is wait until order 103 is sent out and crosses the pond.
Sony VPL-VW50 | Panasonic TX-36PD30 | Vutec Lectric 122" screen | Denon AVR-4308 | Sky HD (1Tb) | Toshiba HD-XE1 | Sony PS3 (A) | Panasonic DMP-BD30 (B) | Philips TSU9600 & RFX9600 | Lutron GRX-3104 | AE Aelite LCR | Sonance Ellipse SUR (2 pair) | M&K V1250THX (x2)
30-03-2008, 1:20 PM
#11 (permalink)
Cheers, though I think your in the minority in using an IR extender to be honest. Would be nice to have it all out of sight but Im sure I'll find somehwere.
And if it were possible to have it on top of the PS3 why would you consider it to be the worst place possible? I cant think why it would be any worse than anywhere else to be fair.
30-03-2008, 6:11 PM
#12 (permalink)
I'd not put it on top of the PS3 because:
It would look unsightly
The top of the PS3 is rounded and gets hot (OK slightly dodgy)
The beauty of BT in this instance is that it doesn't have to be in the same room
All aesthetic reasons not technical I'm afraid.
I'd also have to have to say that anyone paying £40 for a IR solution for the PS3 over the £10 Logic3 or Nyko solutions is way too obsessive not to have an IR extender
John
31-03-2008, 10:43 AM
#13 (permalink)
John
Surely an extender is just as messy and unsightly as this solution anyway if you cannot shut away your equipment. I don't have the option of putting stuff in a cupboard or closed unit. But I do want to use my harmony like a normal remote, i.e to be able to turn the damn thing on.
And the only real reason why on top if the PS3 is worse than anywhere else given no rf extender is that it may get hot. The others aren't really reasons now are they.
31-03-2008, 11:02 PM
#14 (permalink)
Thanks: Gave 10, Got 104
Well personally When I order mine for use with my pronto I'll be experiemnting with trying to hide it where it still gets IR. As an example my Apollo ambient lights have an IR receiver which is stuck facing downwarcds on the back of my screen completely out of sight bugt still gets a signal. I'm hoping to do something similar and hide the IR2BT so it will still get an IR signal but be invisible.
P.S. has anyone who ordered got theirs yet? were there any customs or import charges to pay?
Jamie
Arcam AVR200, MS 500THX Speakers, Philips 42" HD screen, PS3, Philips Pronto RU950
31-03-2008, 11:09 PM
#15 (permalink)
My order was shipped out of Miami at 05:13, 31/03. My order was Bruce's first international order. I'm expecting delivery in 6/7 days.
I'll be sure to report back, once received.
