AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 27-03-2008, 7:32 AM   #1 (permalink)
Thanks: Gave 9, Got 5
Converting (Arcam) Decimal codes to hex
Morning all,
I am trying to input discrete on/off for my arcam FMJ MS250 into my prontopro. In the manual, it lists the remote control codes as follows:
System code for MS250 is 21
Standby-on 21-123
Standby-off 21-124
How does this fit with entering codes in hex, which is how i've entered previous discrete codes?
thx
Denon AVP-A1HD, Denon POA-A1HD, Fujitsu P50HXA58EB, Toshiba HD-XE1, Sony BDP S550, Sky HD (Pace), KEF Reference 203s, 202c, 201s and ci1500s, Velodyne SPL 1200R, Sonos ZP90, ReadyNAS NV+
klnc is offline
Old 27-03-2008, 4:57 PM   #2 (permalink)
Dave964's Avatar
Thanks: Gave 0, Got 78
Re: Converting (Arcam) Decimal codes to hex
21 decimal is 15 hex.
123 decimal is 7B hex and 124 decimal is 7C hex.
The Windows calculator will convert between decimal and hex for you.
Dave
SB+, Chord CPM 2600, Pioneer PDP-428XD, Sky HD, PS3, Sony STR-DA5200ES, MA GS10s, MA GSLCR, MA RSFXs, BK XLS300, Pronto TSU9600
Dave964 is online now
Old 27-03-2008, 7:33 PM   #3 (permalink)
I think you mean that you want to convert these RC5 commands to a hex format for the prontopro.
a) you don't have to... If you go to 'add IR code' there's a RC5/6/MM button which brings up a box to enter system number and command (system number 21, command 123)
b) Using a little pronto-format generator program I have...
Standby ON
0000 0073 000A 0000 0040 0020 0020 0040 0040 0040 0040 0040 0020 0020 0020 0020 0020 0020 0040 0040 0020 0020 0020 09B7
Standby OFF
0000 0073 000A 0000 0040 0020 0020 0040 0040 0040 0040 0040 0020 0020 0020 0020 0020 0020 0020 0020 0040 0020 0020 09B7
Richard.
richardbarman is offline
Old 27-03-2008, 11:05 PM   #4 (permalink)
Richard,
Thanks for response. Yes, you're right, although i was thrown off the trail by the latest prontopro edit software not having the RC5 conversion tool - i had to download the pronto version, enter the code and then copy and paste the hex into prontopro... what a performance!
Anyway, all working now!
klnc is offline
arcam, codes, converting, decimal, hex
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Need help with Arcam discrete codes! Kazuya Mishima Remote Controls 4 22-08-2008 2:29 PM
ARCAM A22 - Discrete IR Codes wanted endora Arcam Owners' Forum 3 10-12-2006 3:30 PM
Remote codes for Arcam DVD players Sparky66 Arcam Owners' Forum 4 28-07-2005 5:13 PM
Arcam DV88+ remote codes taimur DVD Players (Standard Definition and Upscaling) 5 02-06-2003 1:33 PM
Marantz IR codes clash with Arcam Amp AOD Integrated AV Amplifiers and Receivers 5 14-07-2002 7:12 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
