AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 24-03-2008, 2:46 PM   #1 (permalink)
Thanks: Gave 2, Got 2
RU990 Help please
Hi guys and girls im new to this and im after a little help please,
i bought the ru990 and iv had a good go at programming it but im stuck and i need the following i would be grateful for any help,
1) im after the CCF code for Sky+ (Amstrad)
2) im after the CCF code for AV control receiver Panasonic SA-HE7
3) im after the CCF code for satellite receiver Echostar AD3600ip Viaccess
and finally the CCF code for DVDR Sony RDR-GX300
Thanks for looking
Mark.
madpup is offline
Old 24-03-2008, 4:25 PM   #2 (permalink)
stoobie's Avatar
Thanks: Gave 5, Got 52
Re: RU990 Help please
Hi Mark
Have a look over at RemoteCentral there are hundreds of files for download.
Your model uses PCFs but you can import a CCF and use the codes (the actual layouts will not really suit your remote tho'). You can look either under Pronto Classic (CCF) or Pronto NG (PCF) and you will find loads of each.
If you cannot find your precise model, it is always worth trying a similar model as often the codes from them work. (My Panasonic uses the same codes as about 6 other models I found on RemoteCentral)
Of course, if you can't find what you are looking for, you could just download a PCF that you like the look of and learn the codes into it from your original remotes!
Good Luck
Stoobie
Marantz RC9500 & RC5400, Philips Pronto RU990 (Stolen in a burglary 6/10/08 ) & RU940, Pronto Neo, Bang & Olufsen BeoVision 5 Plasma (just arrived!)
stoobie is offline
Old 24-03-2008, 6:34 PM   #3 (permalink)
Thanks Stoobie you are right, it is PCFs that i need, checked over at Remotecentral they haven't got what i need but i'll take a look at similar items maybe i can use one or two..
regards
Mark
madpup is offline
Old 24-03-2008, 7:03 PM   #4 (permalink)
Thanks: Gave 8, Got 103
You could try my Sky PCF. Here it is.
My full PCF is huge, so I've deleted everything except the Sky device to keep the attachment as small as possible.
Oh I'm sure we can handle this situation maturely.... Isn't that right, Mr Poopy Pants?
Jules is offline
madpup (24-03-2008)
Old 24-03-2008, 10:32 PM   #5 (permalink)
Many thanks for that Jules, im sure i can use the colour buttons on your setup
regards
Mark
madpup is offline
ru990
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Pronto SBC RU990 Advice needed Madasafish110 Remote Controls 8 06-05-2008 5:47 PM
RU990 touch screen accuracy Dave964 Remote Controls 0 30-12-2007 5:20 PM
Software download for SBC RU990 wingnut1 Remote Controls 3 27-11-2006 8:33 AM
Philips Pronto RU990 Twan1 Remote Controls 11 12-11-2006 1:21 PM
Problem with IR learning with Proto RU990 gilford Remote Controls 7 14-08-2006 9:07 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
