AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 22-03-2008, 12:29 PM   #1 (permalink)
Thanks: Gave 1, Got 10
X-10 control
Does the harmony 1000 or MX-980 control X-10 modules over RF? If not, what remotes do?
And also if not, does this mean you have to use IR and the X-10 IR module?
mark88 is offline
Old 22-03-2008, 3:11 PM   #2 (permalink)
stoobie's Avatar
Thanks: Gave 5, Got 52
Re: X-10 control
Mark88
I can tell you for definite that the Pronto RU950, 960, 970, 980 & 990 work direct with X10. As do the Marantz RC5200, 5400, 9200 and 9500 (This is via the X10 TM13U/TM13U-AH transciever ) The US equivalents do not have the same RF frequency so do not work directly (they need the IR to X10 transceiver you mention).
I don't think the harmony 1000 does use the same RF and I'm not sure about the MX-980 and I'm not sure if either can control the IR to X10 transceiver.
You can also use all the older Pronto/Marantz models with the IR to X10 transceiver.
Hope that is of some help
Stoobie
Marantz RC9500 & RC5400, Philips Pronto RU990 (Stolen in a burglary 6/10/08 ) & RU940, Pronto Neo, Bang & Olufsen BeoVision 5 Plasma (just arrived!)
stoobie is offline
control, x10
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Control my Digihome PVR through my Samsung TV Remote Control ? gregormcintyre PVRs and VCRs 4 04-02-2008 11:56 PM
I want to use a remote control in my office to control a device in my lounge jon_mendel Remote Controls 3 28-03-2005 8:17 PM
Hitachi 42PD3000 remote control - VCR control via 'Viewlink' ? piknik PVRs and VCRs 0 11-10-2003 11:52 AM
Hitachi 42PD3000 remote control - VCR control via 'Viewlink' ? piknik Plasma Televisions 0 11-10-2003 11:48 AM
Erratic volume control of a Denon AVC-A10SE via remote control GETanner Integrated AV Amplifiers and Receivers 2 16-06-2003 9:36 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
