AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 21-03-2008, 8:01 PM   #1 (permalink)
Thanks: Gave 8, Got 18
688 Help please !
Just picked up a 688 Remote from Comet. However setting it up is driving me crazy. I've installed the software no problem. My AV equipment consists of TV (Panny TH-42PX60B) DVD Recorder ( Panny DMR-EX75EB) HD DVD Player (Tosh EP30) Amp (Sony STR-K880) However to make things 'simple' I only added the TV and DVD Recorder, 3 hours later I'm still struggling ! Basically when I press Watch TV nothing happens. The only way I get a response is to press help then the TV and DVD Recorder switch on both together ! after that the 688 fails to respond. I have to then revert back to the original remote. Any help would be much appreciated Thanks !
bigbaz is offline
Old 21-03-2008, 8:50 PM   #2 (permalink)
Thanks: Gave 19, Got 40
Re: 688 Help please !
The answers will lay with Power & Input settings and the way Panny handles them.
There are a few threads active on these topics at the mo. There are a few of you that have got these from Comet this week so it will be a popular topic. Basically all the Harmony software works the same for all models.
Take a look and then you'll have a better understanding and it will be easier to help you.
Think about the activities you want, what devices they use and whether their Power buttons toggle on/off or whether the Harmony shows discrete commands. Also check the Discrete Inputs provided by the Database. Just because the OEM remote does not have them does not mean they dont exist!
Cheers, Alan
Panasonics TH42PX70 & 80, SkyHD (500gb), LG MD228WD,
Panasonic DMR E55 DVDR, Hauppauge Dual Freeview, 2 x Linksys DMA-2100, Harmony 555, 785 & 885 & TC30 R/C
saintalan is offline
Old 21-03-2008, 9:02 PM   #3 (permalink)
Cheers, Alan
Thanks for that Alan, will keep on persevering !
bigbaz is offline
Old 21-03-2008, 9:09 PM   #4 (permalink)
There are several of us on here that can steer you through it but it will help enormously and save time in the long run if you do a bit of homework.
For you and others who may follow this, get your head around the Software both for initial set up and adding/changing etc.
Explore the Settings for Devices & Activiteis when you have set something up. Follow the prompts and pay particular attention to the Power & Input Settings.
Also be as specific as you can with problems.
Alan
Old 21-03-2008, 10:35 PM   #5 (permalink)
Thanks once again Alan. Think I might just keep hold of the generic remotes a little while longer !
bigbaz is offline
Old 21-03-2008, 10:49 PM   #6 (permalink)
Thanks: Gave 49, Got 98
I got one of these remotes a few weeks back, its taken be since then to get it just the way I want (well about 90% there), I'd say stick with it as I wouldn't want to be without it. I don't really use the activities just the individual controls for each device
Working in the Electronic Plantation.
Xbox Live - Tyler Durden UK PS3 - TylerDurden-UK Wii - 3630 1007 3500 3256
TylerDurden is offline
Old 21-03-2008, 11:37 PM   #7 (permalink)
Originally Posted by TylerDurden View Post
... I don't really use the activities just the individual controls for each device
You really are missing out on the whole point of having a Harmony. I think the word Activities gives people the wrong impression, it just really means "I want to do this and be able to control this, that and the other"!
Bachstrad (22-03-2008)
Old 21-03-2008, 11:52 PM   #8 (permalink)
The problem is that I turn all my equipment off at night, ie not in standby mode. When for example I turn the TV off via the remote, the remote remembers that the TV is off, however, when I power the TV back up it automatically comes on but the remote has not been use and thus as far as its concerned the TV is off, the same goes for my amp etc. The Activities seem to work great if you leave your stuff on standby when not in use. I understand the concept of Activities, ie, Watch DVD, turn TV on, turn Amp on, turn DVD player on, switch to DVD AV channel etc.
Unless I'm missing the point I can't see a way around the problem
Old 22-03-2008, 9:49 AM   #9 (permalink)
...Unless I'm missing the point I can't see a way around the problem
Hi again. I think all you need to do is select Option 1 in each device's Power Settings, to leave the devices on. Then you can power on/off manually without upsetting the Harmony state.
Alan
Old 22-03-2008, 12:18 PM   #10 (permalink)
Alan
Thanks, will check that out later, shame my wife doesn't like the harmony and still uses the original remotes
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
