AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 21-03-2008, 9:34 AM   #1 (permalink)
Thanks: Gave 1, Got 2
Terratec IR-Receiver with Harmony in HTPC
I posted this in the computer section without success, but might get more success in here.....
I've just built my HTPC and all seems fine, but I was hoping to use the IR receiver which came with the Terratec Cynergy 2400i with the my (also new) Harmony 555 remote.
It doesn't seem to work..... is this even possible or am I just doing something wrong with the setup?
CrazyHorseB is offline
Old 21-03-2008, 11:36 AM   #2 (permalink)
Thanks: Gave 19, Got 40
Re: Terratec IR-Receiver with Harmony in HTPC
Does it work with the original remote?
Does it have to be enabled?
Give us a bit more info.
Alan
Panasonics TH42PX70 & 80, SkyHD (500gb), LG MD228WD,
Panasonic DMR E55 DVDR, Hauppauge Dual Freeview, 2 x Linksys DMA-2100, Harmony 555, 785 & 885 & TC30 R/C
saintalan is offline
Old 21-03-2008, 11:18 PM   #3 (permalink)
The ir-receiver works fine with the Terratec remote. I suppose the question i'm asking is; is the terratec receiver linked only to that type of remote or is it a generic reciever that can take and interpret signal from any remote?
Old 21-03-2008, 11:29 PM   #4 (permalink)
If it's like my Hauppauge then the IR recreiver is only linked to the Tuner Card. So your Harmony should be able to control the Tuner but not the PC, Media Centre etc.
harmony, htpc, irreceiver, terratec
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Which IR receiver to use my Harmony 885 with a HTPC? GSXRMovistar Home Cinema PCs 6 12-09-2008 7:48 PM
Terratec IR-Receiver with Harmony in HTPC CrazyHorseB Home Cinema PCs 0 20-03-2008 5:28 PM
Can Harmony Turn on my HTPC Vista aMaTuRePrO Remote Controls 21 15-06-2007 3:25 PM
IR receiver for use with Harmony remote booms Remote Controls 3 26-07-2006 3:12 PM
For trade: terratec Cinergy T2 USB2 DVB-T (Freeview) Receiver bigalow Archive : Completed Business and Expired Threads 3 16-11-2005 6:25 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
