AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 17-03-2008, 7:51 PM   #1 (permalink)
Thanks: Gave 10, Got 0
Looking for One for All Remote
Looking for a one 4 all remote to work, Sky+, Home Cinema and TV.
Any help woul dbe greatly received.
I have found this one and wondered if it is any good for what I need?
http://www.argos.co.uk/static/Produc...2Bcontrols.htm
Dracos Dragon is offline
Old 17-03-2008, 8:03 PM   #2 (permalink)
Thanks: Gave 19, Got 40
Re: Looking for One for All Remote
You can get a harmony 555 for that!
Panasonics TH42PX70 & 80, SkyHD (500gb), LG MD228WD,
Panasonic DMR E55 DVDR, Hauppauge Dual Freeview, 2 x Linksys DMA-2100, Harmony 555, 785 & 885 & TC30 R/C
saintalan is offline
Dracos Dragon (20-03-2008)
Old 17-03-2008, 8:12 PM   #3 (permalink)
mjcairney's Avatar
Thanks: Gave 87, Got 240
Another vote for the Harmony. I have a 655 and just installed a 555 for my sister and her hubby last week - I can't see past them when it comes to universal remotes - the units are great and their support is second to none.
The 555 is available here for £55.28 - well worth it and, in fact, you may even find it cheaper if you search around.
Cheers,
Martin.
Pioneer PDP-435FDE Plasma | Toshiba HD-EP30 | M/R Pioneer DVR-545HX-S (HDMI) DVD/HDD Recorder | Pioneer DV-575A (for SACD and DVD-A playback) | Pioneer VSX-LX60 Receiver | Sky HD | Denon TU-1800DAB Tuner | Kef KHT2005.2 Speakers in 6.1 Configuration | Harmony 655 Remote.
mjcairney is offline
Old 17-03-2008, 8:23 PM   #4 (permalink)
Thanks: Gave 2, Got 9
I'd hang fire & hunt down a Logitech Harmony, I got a brand new 885 for £60 off here the other week
SystonBoy is offline
Old 17-03-2008, 8:43 PM   #5 (permalink)
Thanks: Gave 49, Got 98
Check your local comet, they had the Harmony 688 for £15 recently
Working in the Electronic Plantation.
Xbox Live - Tyler Durden UK PS3 - TylerDurden-UK Wii - 3630 1007 3500 3256
TylerDurden is offline
Old 17-03-2008, 8:58 PM   #6 (permalink)
Thanks for all your replys, reckon Ill save me money and get a Harmony one.
Just got to decide which and how much I want to spend.
Old 17-03-2008, 8:59 PM   #7 (permalink)
Thanks: Gave 29, Got 177
It looks good but that's about all that can be said for it.
The screen has a strange texture, and you have to use a coin to get in to the battery compartment.
One I had soon stopped working but I didn't bother to get it replaced.
Get a Harmony, a cheap 688 at Comet if you're lucky, otherwise splash out on a One - not just any old one!
hhatkin is offline
Old 18-03-2008, 9:01 PM   #8 (permalink)
Last questions I promise:
1) Will the 885 work my home cinema?
Have found this on e-bay and was wondering if this is the 885 as stated.
http://cgi.ebay.co.uk/NEW-LOGITECH-H...QQcmdZViewItem
As its a full 20 quid cheaper than what i can find in UK.
Old 18-03-2008, 9:22 PM   #9 (permalink)
no its the 880 US version with NO colour keys
Old 18-03-2008, 9:29 PM   #10 (permalink)
It says the 880 and 885 are the same - but they're not.
hhatkin is offline
Old 19-03-2008, 12:52 AM   #11 (permalink)
Bachstrad's Avatar
Thanks: Gave 938, Got 236
There are work arounds to enable the 880's for UK use, but I don't think as a Sky HD user I could manage without the coloured buttons. If you don't have Sky and don't use Teletext, then maybe the US model will be OK for you. HTH
ATB
Max
Toshiba 42Z3030D | Toshiba SD360E | Sky HD | TiVo | Yamaha RX-V100D | Mission Fronts | Yamaha Centre & Rears | Yamaha YST-SW80 Active SUB | Harmony 885 | Dell Dim XP MCE | Dell D620 XP Pro | iPod video 60gb
Bachstrad is offline
Old 20-03-2008, 6:15 PM   #12 (permalink)
Thanks for all your replies.
I have bitten the bullet and gone for the 885 off Amazon, just have to make sure the wife don't see the pric.
Old 20-03-2008, 6:50 PM   #13 (permalink)
I have bitten the bullet and gone for the 885 of Amazon, just have to make sure the wife don't see the pric.
Spelling error
remote
Refbacks are On
Thread Thread Starter Forum Replies Last Post
daewoo DVD-R remote - cheap replacement or universal remote wanted! gsc Remote Controls 0 06-06-2007 9:37 PM
SKY Remote ; (Volume on Remote not compatible with LG42"Plasma TV) ericmacdonald Sky and Sky+ 10 01-02-2007 7:35 PM
Does the official xbox360 media remote work as windows MCE remote? L11 Xbox 360 5 05-08-2006 5:06 PM
For Sale: Logitech Harmony Remote 885 Advanced Universal Remote As New MerMan Archive : Completed Business and Expired Threads 16 13-02-2006 11:33 AM
Clearout RGB Sqart, Marantz RC1200 Remote, 5in1 Smart Remote and Senheisser DSP pro Bassbin Archive : Completed Business and Expired Threads 29 18-10-2004 12:52 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
