15-03-2008, 10:07 AM
#1 (permalink)
Thanks: Gave 118, Got 45
Harmony 885 - Arggghhhh!
Sorry sorry sorry sorry ... I just did a search on 885 questions and this has been answered. You have to download and install the updated software because the stuff on the disc is buggy. Apologies for barging in with a new thread.
I just recieved my new Harmony 885 through the post. This is my first universal remote so I'm a newb here.
When trying to set-up my remote it gets to the last checkpoint where it updates my remote, then it tells me my firmware needs updated and to go to support in the member page.
I do this and run the firmware updater and this then tells me that the latest firmware version for my remote is 4.0 and this is already installed on my remote. I run the firmware update anyway and the message pops up on my screen that firmware has been installed successfully.
I download another million files to get to the update page I was on earlier and it tells me "my firmware needs updated and to go to support in the member page."
I do this over and over and over again.
Now I'm getting a little pee'd off with it. Any advice for a struggling noob?
EDIT: I should also note that this would be a hell of a lot less painful if IE7 didn't insist on blocking every download.
"But our trip was different. It was a classic affirmation of everything right and true and decent in the national character. It was a gross physical salute to the fantastic possibilities of life in this country---but only for those with true grit. And we were chock full of that" - HST
15-03-2008, 10:27 AM
#2 (permalink)
Thanks: Gave 5, Got 1
Re: Harmony 885 - Arggghhhh!
firefox is your friend!
tell me how you get on with this remote I'm looking to get one.
how much did you pay for it?where did you get it from?
| Pioneer4280XD | Sky HD | Istar Mini HD | Philips HTS3357 5.1 600w | Xbox 360 | Shuttle (NFS) Streamer |
15-03-2008, 4:53 PM
#3 (permalink)
I got mine from Amazon for £108 delivered. After that initial hiccup the remote has worked first time for all my kit, even the obscure Drundig HDMI set top box I have.
The activities are a joy, just hit one button and it'll sort everything out ready to play Xbox, PS3 (no bluetooth but the joypad turns the PS3 on anyway) or watch TV. It seems very flexible with the customisations so I think with a bit of further playing about I can get the very most out of this remote.
Going from 5 remotes to 1 was worth the money and I defintely have no buyers remorse on this one. Recommended.
Now to get an IR dongle for my PS3.
15-03-2008, 6:34 PM
#4 (permalink)
Thanks: Gave 54, Got 129
Gutted, there was an 885 on ebay a few weeks ago that the seller was getting rid of as faulty because it was doing exactly the same thing as you describe.
Buy it now price was £20 plus delivery.
15-03-2008, 8:24 PM
#5 (permalink)
Thanks: Gave 19, Got 40
I was gutted missing one at £50, they are now going for £75+, mind you I wonder how good the charging connectors are on s/h models?
Panasonics TH42PX70 & 80, SkyHD (500gb), LG MD228WD,
Panasonic DMR E55 DVDR, Hauppauge Dual Freeview, 2 x Linksys DMA-2100, Harmony 555, 785 & 885 & TC30 R/C
16-03-2008, 12:50 PM
#6 (permalink)
I looked on ebay for ages for a cheap Harmony but eventually gave up as most were either going for higher than retail price  or about £10-20 less. I wonder how many people get caught with this firmware thing when really it's nothing to do with the firmware.
I finally decided that having no warranty or return was not worth saving £20 for.
I'm not sure what is meant by S/H models but the charging dock is great on mine and even looks cool too if that's any use.
17-03-2008, 5:04 PM
#7 (permalink)
Does Logitech have a database you can whack your product into to see if the remote can control it?
I want this remote to work with my Philips HTS3357.
17-03-2008, 5:31 PM
#8 (permalink)
Thanks: Gave 938, Got 236
Yes they do, on their website you can download the remote software and check the database for yourself. Click here, it's under 'How To', HTH.
ATB
Max
Toshiba 42Z3030D | Toshiba SD360E | Sky HD | TiVo | Yamaha RX-V100D | Mission Fronts | Yamaha Centre & Rears | Yamaha YST-SW80 Active SUB | Harmony 885 | Dell Dim XP MCE | Dell D620 XP Pro | iPod video 60gb
17-03-2008, 5:44 PM
#9 (permalink)
ATB
Max
thanks dude I'll do it when I get home at work now so can't be downloading random software!
17-03-2008, 5:47 PM
#10 (permalink)
ATB
Max
You can download it but you must register and connect a device before you can access it.
The HTS3357 is in the Database
17-03-2008, 5:59 PM
#11 (permalink)
Cheers mate I've got a Philips universal remote that wont work with the Philips HTS3357 how retarded is that?
so gonna get rid of that and get either this one or the 785. Can get the 785 for £65 New!
