AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 12-03-2008, 9:35 PM   #1 (permalink)
Thanks: Gave 20, Got 20
Logitech Ability ?
Forgive my ignorance but im new to the latest universal learning remotes
Im thinking of buying a secondhand av amp that doesnt come with a remote (due to being damaged) and was wandering if a replacement Logitech could be programmed without the original.
Basically , am i right in thinking that you just link it to a PC and download the correct program codes for the amp in question ?
How comprehensive are these downloadable lists ?
Is it that simple and what if the amp isnt listed - am I then a bit stuck ?
Sharp XV-Z200E, Panasonic TH42PE50B, Pioneer DV989AVI, Sony PS3, Parasound HCA 1205a, Denon AVR3805, Yamaha RX V1500, Pioneer vsx D2011, Focal Chorus 826V, Focal Chorus cc800V, X-Box, Thomson Sky HD, Pace PVR2 Sky+, Neovia 26" LCD, Panasonic db35 sky[/i]
ukroadster is offline
Old 12-03-2008, 10:08 PM   #2 (permalink)
Thanks: Gave 19, Got 40
Re: Logitech Ability ?
Yes it can be that simple.
Let us know the make & model and we can see if it's on the Database. If not a similar model's codes may work.
Otherwise there will (probably) be ways but could get a bit complicated.
cheers
Alan
Panasonics TH42PX70 & 80, SkyHD (500gb), LG MD228WD,
Panasonic DMR E55 DVDR, Hauppauge Dual Freeview, 2 x Linksys DMA-2100, Harmony 555, 785 & 885 & TC30 R/C
saintalan is offline
Old 13-03-2008, 7:30 AM   #3 (permalink)
Thanks Alan
The model is a Pioneer VSA AX10AI av amplifier.
It would be great if you could tell me if its listed as the replacement original remote is £300
Andy
Old 13-03-2008, 8:36 AM   #4 (permalink)
davepuma's Avatar
Thanks: Gave 114, Got 861
I haven't come across anything that isn't listed on the database yet myself. You can download the software and try it before you buy a remote, so in effect you can have it setup before you get the remote!
AV Setup Toshiba 36ZD26P | Panasonic TH42PZ81 Coming Soon! | Hitachi PJTX200 | Toshiba HD-EP35 | Pioneer DVR540HX-S | SB3 | Xbox360&PS3 | Sky HD & FreeSat | Denon AVR3805 | Arcam Alpha7&8 | Tannoy Mercury | SVS PB1-ISD | Harmony One |
davepuma is offline
Old 13-03-2008, 9:24 AM   #5 (permalink)
Hi DavePuma
Have u got a link for the software download so i can check please
Old 13-03-2008, 11:17 AM   #6 (permalink)
Unfortunately, I do not think it is available anymore. You have to connect a Remote & Register.
Will check the model when I can.
Alan
Old 13-03-2008, 11:23 AM   #7 (permalink)
davepuma's Avatar
I wasn't aware that you couldn't do it anymore but it still looks like you can. Try HERE
davepuma is offline
Old 13-03-2008, 11:39 AM   #8 (permalink)
Andy Hi
Yes it shows as an AV Receiver. I have downloaded it as a device but of course I cant test it. Let me know if you want me to check for specific commands, but it seems pretty comprehensive.
Dave
I was unable to use that before I purchased mine about a month ago. I'll try again registering as a new member to see if it will let me.
Old 13-03-2008, 12:16 PM   #9 (permalink)
Thanks Alan
Thanks for going the extra mile
Hopefully the majority of commands will function ok and once its fully set up its only the general functions that i will need.
What is the cheapest Logitech remote you would recommend that does what i need ?
Andy
Old 13-03-2008, 1:26 PM   #10 (permalink)
No problem Andy, happy to help, can you remember a time without these forums? I spend long enough now messing with technology, to think how long that could be!
I just got the 555, I paid sub £50 on the web. Whilst I think the Harmony's are great, they do struggle to get the key size/layout IMHO. Many say that is cured with the ONE but it does not have the 4 colour buttons.
Whilst I love messing with them my main aim is to guide the wife through the technological jungle she says she lives in! So the ACTIVITIES concept works great (though you do have to get your head around & accept the concept).
The 555 has 4 Visible (at a time) activities and my plan was to get another but now am thinking of getting a s/h 885 off ebay as it has 8 visible (& colour) activities and a slightly better key arrangement. However I think the 555 is better looking, so I guess you have to jump in somewhere!
The good thing whatever one you get is the Software is the same as are the functions. You can compare them on the Logitech site but they do show images of the US models!
Let me know if I can help more, either now or when you've taken the plunge!
Alan
Old 13-03-2008, 1:33 PM   #11 (permalink)
Thanks Alan
Yes these forums are invaluble at times
The last universal remote i had was a cambridge M1 and i suspect things have moved on a bit since then. Ill have a look at the link you provided and decide where to 'jump in'.
Thanks again
Andy
ability, logitech
Refbacks are On
Thread Thread Starter Forum Replies Last Post
I want BBC HD + recording ability cheap! GarethG Sky HD 8 22-11-2007 11:20 AM
Logitech Remote Software - 7.0.2+ - Macro Ability Software Update July dgharwood Remote Controls 12 01-06-2007 6:53 PM
Why Sony ripped off the PS2 ability of PS3? littlelio PS3 4 25-03-2007 11:05 AM
No EDIT ability???? Badger0-0 Forum Feedback, Help and Old News 6 08-10-2006 6:56 PM
Sky + copy to vhs ability malcom Sky and Sky+ 1 12-09-2001 6:26 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
