AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 11-03-2008, 4:47 PM   #1 (permalink)
Thanks: Gave 0, Got 3
Question Hello peeps hoping your advice will continue my purchasing of home automation :o)
I'm going to be getting a Harmony 1000 remote for my birthday April 5th and wanted to get many other devices to use with it! I've hopefully found a website that will provide the require z-wave devices for lighting and control of my subwoofer. Will the following devices work with the above mentioned remote.
http://www.letsautomate.com/11144.cfm?
Now on this site i want the lamp, socket and dimming modules but i'm hoping the harmony will control these directly instead of a control module?
Would i need to buy the RF Extender to use the z-wave or can the remote do it anyway?
Thanks for your time and patience answering.
P.S if any of you have any ideas about what to control with this remote be my guess and add them
http://www.speedtest.net/result/142389226.png Themescene HD72i projector, Silverstone LC20B-M HTPC, DiNovo Edge, Harmony 1000, NAD T471 AV reciever, Whalfdale bookshelf speakers x5, SVS PB12 plus 2 Home Cinema Subwoofer, Virginmedia V+ Box, OPHIT DVI Swticher
massivedragon is offline
Old 13-03-2008, 11:32 AM   #2 (permalink)
Thanks: Gave 144, Got 52
Re: Hello peeps hoping your advice will continue my purchasing of home automation :o)
No you do not need the RF Extender to control the plugs etc... they all contain zwave receivers in their own right.
The choice of zwave devices in this country is limited but this will hopefully increase in time and hopefully get more comprehensive in type of devices too !
The RF Extender is just needed if you wish to control IR devices (AMP, DVD player etc) that are not in line of sight from the remote.
The Den
mrm3 is offline
Old 13-03-2008, 11:36 AM   #3 (permalink)
Oh and I use my Harmony mainly through the RF reciever as my AV equipment is in a cupboard...see sig.
I also have 2 plug sockets connect
a) one is for a water pump which I need to turn off now and again
b) other is for the sky box which needs to be rebooted now and again and saves me getting to the socket
friend uses two lamp sockets for dimming when he switches to movies...
The Den
mrm3 is offline
Old 13-03-2008, 2:20 PM   #4 (permalink)
Thanks: Gave 4, Got 14
Can you confirm that the Harmony 1000 is definitely compatible with Z-Wave - I've heard conflicting stories.
hooray33 is offline
Old 13-03-2008, 4:04 PM   #5 (permalink)
I've done some more digging including reading posts from the chap who runs letsautomate to say the 1000 does not use Z-Wave as planned. If this is the case can I ask what kind of sockets you have got to work with the RF extenders?
hooray33 is offline
Old 14-03-2008, 7:55 PM   #6 (permalink)
Sorry I use the Harmony 895 which has zwave.
Thought the 1000 did too...apologies!
The Den
mrm3 is offline
Old 14-03-2008, 8:14 PM   #7 (permalink)
Assured Advertiser
Thanks: Gave 4, Got 51
The new NEVO Q50 does have Z-Wave built in as an alternative to the Harmony 1000
http://www.quantumelectronics.co.uk/.../nevo_q50.html
Quantum Electronics (UK) Ltd is proud to be an Assured Advertiser on the AV Forums.
www.quantumelectronics.co.uk or email sales@quantumelectronics.co.uk
See our Onkyo AV Price Reductions
Click for our latest Home Cinema Package Prices
QuantumUK is offline
Old 14-03-2008, 9:16 PM   #8 (permalink)
SG-22's Avatar
Thanks: Gave 78, Got 145
quite an expensive alternative though at £450!!
Samsung PS50Q97HDX - Toshiba HD-E1 - SKY - PS3(60GB) - Xbox360 - Harmony 1000 - Onkyo 606 - Mordaunt Short Alumni
HTPC - ASUS P5E-VM HDMI/Intel Core 2 Quad Pro Q6600/Ultra DDR2 2.0GB/Vista/Samsung 500GB/Antec
SG-22 is offline
Old 16-03-2008, 12:32 AM   #9 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,105
But you can buy from the US (different Z-wave freq) much much cheaper try a search. 1000 does use Z-wave ut there are issues with 3rd part Z-wave devices the 895 is the much better alternative (dont worry bout the lack of touch scren its far better for not having one)
hornydragon is offline
Old 27-03-2008, 12:12 AM   #10 (permalink)
Thanks: Gave 11, Got 0
i use the 895 and that controls variolight touch dimmer switches perfect
you can get these here
http://www.theinternetswitchstore.co.uk/view.php?cat=22
i went down this route instad of zwave...
hope that helps
mark
SoloSid is offline
Old 29-03-2008, 4:59 PM   #11 (permalink)
jason1wood's Avatar
Thanks: Gave 13, Got 11
can you control these with a Harmony 785???
TV:-Pioneer 4280XD. Sound System:-Harman Kardon HS200. DVD:-Denon 1930. Remote:-Harmony 785.
jason1wood is offline
advice, automation, continue, home, hoping, peeps, purchasing
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Advice on Netstreams Digilinx Home automation Steve L Custom Installers and Installations 5 04-01-2008 10:32 PM
need some advice. home automation to be controlled via MCE only. andywee Home Automation, Lighting, Security, Heating and Cooling 1 21-03-2007 9:00 PM
Any legal peeps out there... quick bit of advice required. Mac Man General Chat 7 09-01-2007 12:26 PM
Hoping for some Xbox 360 Connection Advice samuel pepys Xbox Live 11 17-04-2006 10:44 AM
Some Career Advice Please - High-End AV & Home Automation Installations DJBurgess Home Cinema Magazines, Industry and Jobs 2 14-02-2006 2:18 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
