AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 11-03-2008, 10:28 AM   #1 (permalink)
fredsie's Avatar
Thanks: Gave 71, Got 78
Harmony 885 first use
Just got my 885 and seem to be stuck at the first (or maybe second!) hurdle. I seem to be in a never-ending loop.
I have charged the remote, installed the software, and set up my devices and activities on the website. But when I tried to send (the initial) update to the remote a pop-up appeared that said I must upgrade my firmware. I went to the firmware upgrade page and started the process - it said I already have the latest firmware, so I tried the update again - same result!
So I went back to the firmware upgrade and went ahead with it, even though it said I already had it. This seems to work OK, the remote reporting successful upgrade.
Back to the update - same popup "you must upgrade your firmware".
Not a happy start!
fredsie is offline
Old 11-03-2008, 10:30 AM   #2 (permalink)
Bachstrad's Avatar
Thanks: Gave 938, Got 236
Re: Harmony 885 first use
Not a happy start!
If you update the actual Harmony software on your computer, you'll find this problem will disappear. HTH.
ATB
Max
Toshiba 42Z3030D | Toshiba SD360E | Sky HD | TiVo | Yamaha RX-V100D | Mission Fronts | Yamaha Centre & Rears | Yamaha YST-SW80 Active SUB | Harmony 885 | Dell Dim XP MCE | Dell D620 XP Pro | iPod video 60gb
Bachstrad is offline
fredsie (11-03-2008)
Old 11-03-2008, 1:07 PM   #3 (permalink)
fredsie's Avatar
Dead right, Max, exactly as the guy at Logitech was telling me as you were posting your message! Apparently the software version on the disc is incompatible with the firmware version on the remote, both out of the same box!
fredsie is offline
Bachstrad (11-03-2008)
Old 11-03-2008, 1:11 PM   #4 (permalink)
Pincho Paxton's Avatar
Thanks: Gave 30, Got 193
Not a happy start!
This is just a misinterpretation of the events that you are seeing. And the misinterpretation is Logitechs fault, because the software is badly written. The actual update is found on a seperate page to the normal opening sequence. I too went through this a few times before I clocked on that when it says it is updating my sytem it is in fact just opening the setup screen.
The seating distance thing is quite annoying. Yeah it looks great from 20ft away.. so does my ex!!!. If you can ignore grain, then it's easy to ignore someone that is sending out a lot of noise that you don't like to hear. By the way, I'm being artistic. But maybe you just don't get it.
Pincho Paxton is offline
Old 11-03-2008, 1:13 PM   #5 (permalink)
Bachstrad's Avatar
Glad you sorted it Fredsie, it happened to me in a different way. I made a few adjustments to my Activities and went to update them onto my remote. I kept getting the same message as you and only found the reason why by getting on to the Logitech customer service line to vent my frustration.
In my case, I at least knew that my 885 was a good piece of kit as I'd had no problems with it previously. For you it must have been quite disconcerting to say the least!
ATB
Max
Old 11-03-2008, 1:16 PM   #6 (permalink)
Bachstrad's Avatar
There's no misinterpretation ... it's just as Fredsie says, the current firmware isn't compatible with the old PC software. Update the PC software and the problem is no more.
ATB
Max
885, harmony
Refbacks are On
Thread Thread Starter Forum Replies Last Post
harmony 895 and the US of A celtic13 Remote Controls 2 13-11-2007 5:15 PM
For Sale : Harmony 1000 or Harmony 895 marksimonwright Archive : Completed Business and Expired Threads 48 15-10-2007 9:09 AM
Harmony 885 v Harmony 895 Whats the difference ? Ginnser Remote Controls 2 14-01-2007 6:24 AM
Harmony 525 dazza1210 Remote Controls 1 08-01-2006 4:24 PM
Harmony 525 verses Harmony 360 Grobnic Remote Controls 2 11-12-2005 11:56 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
