Charging/battery problem with Marantz RC5200
Morning,
I've had a RC5200 for about 5 years and it's been great. Now though it's only working for about twenty minutes before the battery runs out. Now I suppose this could be a problem with the battery or the charger, any ideas on which is more likely?
Where do you get new battery packs for it? I know the RC9200 (or is it the RC9400?) uses the same battery. Wasn't there a virtually identical Philips Pronto model, or am I thinking of the Marantz 5000 and Pronto...? Will this use the same battery pack?
Any help would be appreciated...
Regards,
Kris.
