Re: MX-980, MX-810 or waiting HarmonyOne RF?
Personally, I would go with manually programmed remotes such as the MX-980 over wizard-based remotes (Harmony, MX-810) any day. I've tried programming the MX-810 and although it has all the features of the other URC remotes, I found it very difficult to get it to do what I wanted.
I can't imagine any of those devices would be any issue with the MX-980 - the database is pretty extensive plus you can always learn codes to it. Is there a reason why you're thinking about the 980 over the MX-900? The whole range is more or less the same (and work with URC's RF extenders), the only bonus the 980 has is variables (which you will rarely use) and pretty coloured buttons :P
I'm new to X10...I have seen the X-10 codesets in the IR database but I don't know the extent of universal remotes to control it...do you literally just have an IR to X10 converter and then learn the IR? Maybe I'm just naive.
