Re: Using a PDA as remote
Some PDA's are better than others IR range wise but the main downside I see is if its your phone as well what happens when you are out? fine if you live on your own I guess.
also if you get a call how do you mute or pause? I'd recommend a dedicated device. My old Sony Palm Clie PDA had excellent IR range but I never saw it as more than a novelty or standby.
Having said that I did consider a cheap 2nd hand PDA at one point to use as a dedicated remote. My plan was to be able to use the browser and WiFi to control SlimServer on my PC as well using the web interface. this would have allowed music selection, playlists and album art without firing up the plasma but compared to my pronto the IR control software was limited at best so the idea was shelved
