AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Other Home Cinema Essentials > Remote Controls
LinkBack Thread Tools Display Modes
Old 12-11-2007, 12:11 PM   #1 (permalink)
Thanks: Gave 0, Got 4
Harmony 1000, differences between UK and US models?
Hello All,
As the thread says is there any difference between buying a UK model Harmony 1000 and the US version?
Ta
windymillers is offline
Old 13-11-2007, 1:53 PM   #2 (permalink)
Re: Harmony 1000, differences between UK and US models?
I would like to know this as well, going US soon and they are alot cheaper out there.
Sony Bravia 42" LCD Rear Projection KDF-E42A12U
Sony DAV-DZ830W(DVD player & Surround Sound)
Sky HD
XBox360
lky2k23 is offline
Old 18-11-2007, 12:06 AM   #3 (permalink)
I hope you have better luck than me!
I went in Circuit City and Best buys out there, couldnt find a cheap Harmony 1000 anywhere!
They were cheaper here
Plasmas were cheap though
Old 19-11-2007, 10:00 PM   #4 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 10, Got 104
No difference other than the power pack. this does work on 110-240 though so you'll just need a plug adapter
JimBobVFR400 is online now
Old 19-11-2007, 10:51 PM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,105
Wrong i am afraid the Z wave frequency liscened for use in the US is differnet to the UK/Europe so a US remote wont communicate with UK base station, or any other UK 240V Z-wave devices so no control of lighting etc in the UK with a US spec 1000
hornydragon is offline
Old 20-11-2007, 11:59 AM   #6 (permalink)
Thanks: Gave 13, Got 10
will a US 1000 operate rako lighting?
Doctor_AB is offline
1000, differences, harmony, models
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Differences between Samsung Models eeef All-in-one Systems 1 05-10-2007 1:08 PM
Differences between the Philips 5960 models donerkebab DVD Players (Standard Definition and Upscaling) 1 17-10-2006 3:48 PM
Samsung Plasma Models - differences? fifieldn Plasma Televisions 1 04-09-2006 11:25 AM
Tosh email: 'slight differences' in UK models Canary_Jules HD DVD Players 15 27-05-2006 4:19 PM
Here are the differences in both PS3 price models. Rott PS3 152 10-05-2006 2:31 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
